Problems with x-y plots
Problems with x-y plots - Сообщения
#1 Опубликовано: 30.10.2024 01:05:28
Mick
Mick
2 сообщений из 18 понравились пользователям.
I have just tried to use Smath, after a break of two or three months. I can't get the x-y Plots to work. When I try to adjust the scales, etc, from the defaults, I get the message "object does not match target type" in most/all sections.
I checked with an older file that used x-y Plots - the plots displayed properly, but I still got the same messages when I tried to access the scales, etc.
When I launched Smath yesterday I was offered a new, updated version - I accepted - was this a mistake, has something changed?
Any help would be gratefully accepted.
TIA
Jon
#2 Опубликовано: 30.10.2024 01:45:05
1402 сообщений из 1708 понравились пользователям.
Show us what it looks like.
You are the first of 1500 users to have this problem.
#3 Опубликовано: 30.10.2024 20:08:33
Mick
Mick
Hi
Here's a screenshot.
Jon
#4 Опубликовано: 30.10.2024 20:26:32
Very interesting. What operating system, SMath Studio version and X-Y Plot version?
Yes, there has been some updating, but no such side effects have been observed yet.
#5 Опубликовано: 30.10.2024 22:20:38
It seems, this error could not be replicated on linux.
#6 Опубликовано: 30.10.2024 22:41:01
Mick
Mick
Thanks for your interest.
Windows 11 Home
Is this what you mean?
Jon
#7 Опубликовано: 30.10.2024 23:31:50
Yes.
The problem may be related to the fact that you don't have the required version of .Net Framework installed. Usually the current version is sufficient, but the component itself is developed using an older version (.Net Framework 2.0). Try checking or installing version .Net Framework 2.0 or 3.5 for Windows 11.
It's strange that the component worked on the same machine before. Others have no problem because they are most likely running older versions of operating systems or have the required versions of the .Net Framework.
#8 Опубликовано: 30.10.2024 23:58:07
No problems here as well.
XYplot.sm (9 КиБ) скачан 72 раз(а).
If you install the development tools plugin, in the "Insert" > "Development tools" > "System informations" dialog you can retrieve all the relevant framework and system information.
Показать спойлер
#9 Опубликовано: 31.10.2024 01:16:03
Mick
Mick
Thanks for your help, guys. This is starting to reach the bounds of my competence!
These are the details of my system.
SMath System Details.txt (1 КиБ) скачан 61 раз(а).
The XYplot.sm file works and displays fine, but I still get the "object does not match target type" message if I try to format the plot.
I'm a high-level, maths type of user, not a low-level/OS nerd, so I've never messed around with .Net Framework before (or even heard of it!). I'll have to find out what it's all about. Hopefully changing to an older version won't screw up anything else I'm using. Or, at least I can get back to where I am now.
Jon
#10 Опубликовано: 31.10.2024 01:24:18
Mick
Mick
I seem to have version 4.8.9032.0 of .Net
Jon
#11 Опубликовано: 31.10.2024 01:26:28
You're welcome. As for sure you miss any framework before 4.0
It should be enough to install the framework 3.5, you can found detailed instructions here.
The frameworks before/after 4.0 are different and run as parallel entities.
#12 Опубликовано: 31.10.2024 02:12:36
Mick
Mick
I've just downloaded .Net 3.5, using the instructions at
https://www.howtogeek.com/880208/how-to-enable-net-framework-2-0-and-3-5-in-windows-11/
which I found before I saw Davide's reply. They appear to be doing much the same thing.
Unfortunately, there is no change - I still cannot format the XY plot.
Any other suggestions, anyone?
Jon
#13 Опубликовано: 31.10.2024 12:44:33
You can install an older version from the list here:
https://smath.com/en-US/view/XYPlotRegion/history
1. Remove the current version of the plugin from the program.
2. Restart the program.
3. Drag the archive with the plugin to the program window with the mouse. This is an alternative installation method.
#14 Опубликовано: 01.11.2024 23:39:51
Mick
Mick
Thanks for this Uni.
Things have got a bit busy here lately - I'll try these in the next few days and get back to you.
Jon
#15 Опубликовано: 09.11.2024 22:55:24
Mick
Mick
I seem to have solved my problem. While looking to delete and try an older version of XYPlot, it occurred to me to uninstall & reinstall Smath. So I did, and it worked! Everything now seems to work as expected - so far. Maybe I should have thought of that before!
Thanks for your help, all.
Jon
Davide Carpi 10.11.2024 21:32:00
