Units in variables from a matrix
Units in variables from a matrix - Сообщения
#1 Опубликовано: 11.06.2023 06:37:44
AR
AR
Hi
I have a dataset (using Excel-file as a source) from where I get values with vlookup, but I am unable to set units properly.
Values retrieved from a matrix have these square brackets around them [], and it makes working with units really difficult.
I was able to convert mm to m (my database has plain values, but they are supposed to be mm). But next step is to display final results in kN/m, but I keep getting kg/s^2.
I am able to remove units completely and display the correct result without units displayed, but this is suboptimal.
EDIT: I'm using importData plugin
#2 Опубликовано: 11.06.2023 09:51:55
Suggestive ...
#3 Опубликовано: 11.06.2023 11:37:52
You either need to alter your dataset or do corrections after import.
I am not promising anything but maybe units can be imported as they are.
But we need your dataset and smath file for to check if it can be done.
#4 Опубликовано: 11.06.2023 15:32:41
Alvaro Diaz Falconi
Alvaro Diaz Falconi
... I was able to convert mm to m (my database has plain values, but they are supposed to be mm). But next step is to display final results in kN/m, but I keep getting kg/s^2. ...
Hi. Something like this?
#5 Опубликовано: 11.06.2023 15:52:33
Suggestive ...
... Think in terms of sub-utilities you may need to apply.
#6 Опубликовано: 11.06.2023 18:35:16
My guess is his data is something like this.
That's what I deduce from his description at least.
Without him posting datasheet we can't help any further.
Alvaro Diaz Falconi 11.06.2023 23:10:00
#7 Опубликовано: 12.06.2023 03:30:41
AR
AR
Thanks for your replies, here are the files.
I would like to display variable z as kN/m instead of that kg/s^2
#8 Опубликовано: 12.06.2023 05:29:17
You have to customize the result units in the rightmost placeholder.
sergio 12.06.2023 05:44:00
#9 Опубликовано: 12.06.2023 07:01:46
AR
AR
Thank you! I don't know how I didn't get that working couple days ago, I tried to write units outside of brackets but didn't succeed. But now it works no problem
#10 Опубликовано: 12.06.2023 08:43:56
You're welcome
