1 страниц (3 вхождений)
Generating multiple plots using loop with series name (legend) - Сообщения
#1 Опубликовано: 15.12.2024 20:21:27
I am using XY plot to generate multiple graphs, however I am doing it manually. How can I
1] Script a loop to dynamically generate multiple plots
2] Dynamically generate series name (which will be used for plot legend)
NaOH_Demiwater_VECTOR.sm (23 КиБ) скачан 70 раз(а).
#2 Опубликовано: 15.12.2024 23:26:07
If Maxima is an option for you, then you can entirely automate the production of plots.
For an overview on available plot objects and options see SMath with Maxima.
In X-Y Plot, you can use geometric objects to create the lines and perhaps also a legend.
BTW, there is no point of naming the variable Load.kAmp, because the value is converted to A anyways directly upon storage, unless you just store a number, bypassing the SMath unit system. When you retrieve numerical values, you decide what units to use, independently of what was originally used to specify the value.
![2024-12-15 17_20_47-SMath Solver - [NaOH_Demiwater_VECTOR_Kr.sm].png](/ru-RU/file/Hn75yo/2024-12-15-17_20_47-SMath-Solver---_NaOH_Demiwater_VECTOR_Kr_sm__png)
NaOH_Demiwater_VECTOR_Kr.sm (208 КиБ) скачан 70 раз(а).
usamakhan 16.12.2024 00:25:00
Новые сообщения
Нет новых сообщений
