1 страниц (8 вхождений)
[Custom Functions] Linear Interpolation - Сообщения
#1 Опубликовано: 04.07.2019 17:18:01
First of all I don't know if this method is supported, it would be very useful if not.
So if this is not a feature please forgive me because I considered as a bug.
The "InterBilinear" function gives wrong results if matrix is used for x or y value.
interpolation.sm (15 КиБ) скачан 148 раз(а).
Davide Carpi 05.07.2019 04:41:00
#2 Опубликовано: 05.07.2019 00:34:26
WroteFirst of all I don't know if this method is supported, it would be very useful if not.
Mathcad Bicubic can't be reproduced, even "if it could be"
would be useless whereas Smath does not have Matrix 3D plot [only 3 cols].
Your metric X,Y directions aren't correct. You can metric like center as well.
You can have surface plot, only... rotate the plot at will.
interpolation [Oterwise metric X, Y Directions].sm (33 КиБ) скачан 97 раз(а).
#3 Опубликовано: 05.07.2019 01:19:17
Hi overlord. I prefer source code in a high level language, even it could be slowest.
interpolation bilinear source code.sm (26 КиБ) скачан 109 раз(а).
#4 Опубликовано: 05.07.2019 01:41:17
WroteYou can have surface plot, only... rotate the plot at will.
You can have it otherwise from the X_Y surface plot.
interpolation [Oterwise metric X, Y Directions].sm (95 КиБ) скачан 89 раз(а).
#5 Опубликовано: 05.07.2019 03:16:06
WroteYou can have it otherwise from the X_Y surface plot.
... you can create the matrix and the X, Y directions at will.
Then just interpolate ... Spline linterp has the virtue equivalent quadratic.
It would be mistake to cspline.
Bilinear SplineInterp [Construct USER].sm (12 КиБ) скачан 73 раз(а).
#6 Опубликовано: 05.07.2019 04:39:22
It is a bug, thank you! 4th and 5th argument type isn't checked, therefore (unintentionally) vector math applies.
#7 Опубликовано: 05.07.2019 09:15:23
Two things here:
1. The 4th and 5th arguments are presented in reverse order compared to Mathcad
2. The two dimension spline coding is from unknown source
...neither from either Smath [linterp, cinterp, ainterp]
...could be from erroneous quadratic source code.
As given in the attached: Spline(x,y,M) assumed = Mathcad Bicubic2D(x,y,M,vx,object)
At this point, you can spline/plot/rotate the surface as suggested before
Bilinear SplineInterp [Construct USER].sm (24 КиБ) скачан 87 раз(а).
#8 Опубликовано: 05.07.2019 13:31:12
WroteTwo things here:
InterpBilinear(vx,vy,M,object,vector) ... does not collect"vector wise"
InterpBilinear(vx,vy,M,object,valueX) ... correct
That is the answer to the "bug",
Новые сообщения
Нет новых сообщений
