[Custom Functions] Linear Interpolation
[Custom Functions] Linear Interpolation - Сообщения
#1 Опубликовано: 04.07.2019 17:18:01
First of all I don't know if this method is supported, it would be very useful if not.
So if this is not a feature please forgive me because I considered as a bug.
The "InterBilinear" function gives wrong results if matrix is used for x or y value.
interpolation.sm (15 КиБ) скачан 148 раз(а).
Davide Carpi 05.07.2019 04:41:00
#2 Опубликовано: 05.07.2019 00:34:26
Mathcad Bicubic can't be reproduced, even "if it could be"
would be useless whereas Smath does not have Matrix 3D plot [only 3 cols].
Your metric X,Y directions aren't correct. You can metric like center as well.
You can have surface plot, only... rotate the plot at will.
interpolation [Oterwise metric X, Y Directions].sm (33 КиБ) скачан 97 раз(а).
#3 Опубликовано: 05.07.2019 01:19:17
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi overlord. I prefer source code in a high level language, even it could be slowest.
interpolation bilinear source code.sm (26 КиБ) скачан 109 раз(а).
#4 Опубликовано: 05.07.2019 01:41:17
You can have it otherwise from the X_Y surface plot.
interpolation [Oterwise metric X, Y Directions].sm (95 КиБ) скачан 89 раз(а).
#5 Опубликовано: 05.07.2019 03:16:06
... you can create the matrix and the X, Y directions at will.
Then just interpolate ... Spline linterp has the virtue equivalent quadratic.
It would be mistake to cspline.
Bilinear SplineInterp [Construct USER].sm (12 КиБ) скачан 73 раз(а).
#6 Опубликовано: 05.07.2019 04:39:22
It is a bug, thank you! 4th and 5th argument type isn't checked, therefore (unintentionally) vector math applies.
#7 Опубликовано: 05.07.2019 09:15:23
Two things here:
1. The 4th and 5th arguments are presented in reverse order compared to Mathcad
2. The two dimension spline coding is from unknown source
...neither from either Smath [linterp, cinterp, ainterp]
...could be from erroneous quadratic source code.
As given in the attached: Spline(x,y,M) assumed = Mathcad Bicubic2D(x,y,M,vx,object)
At this point, you can spline/plot/rotate the surface as suggested before
Bilinear SplineInterp [Construct USER].sm (24 КиБ) скачан 87 раз(а).
#8 Опубликовано: 05.07.2019 13:31:12
Two things here:
InterpBilinear(vx,vy,M,object,vector) ... does not collect"vector wise"
InterpBilinear(vx,vy,M,object,valueX) ... correct
That is the answer to the "bug",
