"Structural Beam Analysis" plugin error
"Structural Beam Analysis" plugin error - Index outside matrix boundaries error - Сообщения
#1 Опубликовано: 16.01.2020 10:58:36
e.artola
e.artola
Hi everybody,
I'm trying to use the Structural Beam Analysis plugin, but I've got some problems.
When I open the “Beam Analysis” example I've got the next problem.
The error says "Indice fuera de los limites de la matriz" (Index outside matrix boundaries)
Could somebody help me with that?
Thanks in advance
#2 Опубликовано: 16.01.2020 15:38:24
Will be easier to doctor from the document, isn't it ?
#3 Опубликовано: 17.01.2020 04:46:25
e.artola
e.artola
I've got the problema with the example that's why I didn't send the file before.
You can find it attached.
Thanks
Beam Analysis Input Guide.sm (86 КиБ) скачан 138 раз(а).
#4 Опубликовано: 17.01.2020 12:14:18
Ruben Sidranski
Ruben Sidranski
17 сообщений из 463 понравились пользователям.
Do an AppVersion on the file
There has been a lot of work under the engine by the developers since this was issued. You'll need to update it and preferably, repost. I don't do a lot of beam calcs, so I have not touched this in a while.
NOTE: Opened fine in 7251
#5 Опубликовано: 17.01.2020 13:56:19
I have the same problems as Eneko, with 7251 versions of SM
#6 Опубликовано: 17.01.2020 15:56:49
e.artola
e.artola
I've tryed in different ways to fix it but I continue with the same error.
#7 Опубликовано: 17.01.2020 23:57:33
CBG
CBG
77 сообщений из 312 понравились пользователям.
works perfectly on SS7251
Carlos
#8 Опубликовано: 18.01.2020 00:01:12
NDTM Amarasekera
NDTM Amarasekera
There has been a lot of work under the engine by the developers since this was issued.You'll need to update it and preferably, repost.I don't do a lot of beam calcs, so I have not touched this in a while.
The original file showed Red while opening, but finally opened successfully in SS 7251.
Then saved as with a new name, which opens later without any such hassle.
#9 Опубликовано: 21.01.2020 08:12:13
e.artola
e.artola
Could somebody show me how to solve it please?
Thank you in advance
#10 Опубликовано: 21.01.2020 11:48:48
NDTM Amarasekera
NDTM Amarasekera
The renamed file is attached, including the PDF. I did not do any changes.
Hope you will be able to open it. Also update relevant plug-ins.
Cheers!.
Beam Analysis Input Guide_TEST.sm (387 КиБ) скачан 118 раз(а).
Beam Analysis Input Guide_TEST.pdf (486 КиБ) скачан 127 раз(а).
#11 Опубликовано: 21.01.2020 12:09:10
I confirm the problem highlighted by Eneko also on my pc with win7 Pro and SM SM "0.99.7251.32800".
The only dependency reported in the guide is the plugin "Structural Beam Analysis
Utility Functions by Redem Legaspi Jr." that is set up and active.
#12 Опубликовано: 21.01.2020 12:13:54
NDTM Amarasekera
NDTM Amarasekera
Mine is Win 10 Home Edition. SS version same as yours.
Cheers!
#13 Опубликовано: 21.01.2020 12:43:03
1402 сообщений из 1708 понравились пользователям.
Page Beam Analysis Utility Functions exists but I see this plugin for the first time. If anybody find sources I can update them to work state.
Цитата
Analysis of Beam with any number of supports and with any type of loadings.
The worksheet requires that the associated Plugin (Structural Beam Analysis Utililty Functions by Redem Legaspi Jr.) be downloaded and enabled from SMath Studio Extension Manager tool.
The worksheet does the following:
1.) Plots Beam Diagram, Shear Diagram, Moment Diagram, Deflection
2.) Calculates Support Reactions
3.) Calculates Shear, Moment, and Deflection at any given point.
Refer to 'Beam Analysis Input Guide.sm' on how to use the plugin.
redemlegaspi1968@gmail.com
sergio 21.01.2020 12:55:00, NDTM Amarasekera 21.01.2020 14:53:00
#14 Опубликовано: 21.01.2020 13:21:13
Zigor Marroquín Martínez
Same problem as Eneko and PompelmoTell :___(
Thanks fro helping ndtma and uni!
#15 Опубликовано: 27.01.2020 07:52:07
Hi uni and thank you very much for offering your help.. I'm going to try to find the sources you asked for, mailing Redem Legaspi. Any specific file or extension?
Hugs!
Zigor
#16 Опубликовано: 27.01.2020 08:49:15
Redem Legaspi can ask Anrey how to upload sources to svn. After that we'll can maintain his project without author.
As far as I can see, the last update was made by Andrey. Maybe he has sources.
#17 Опубликовано: 27.01.2020 11:14:01
You're right, uni..
I've already contacted Redem and he suggested me also writing Andrey; Redem can't recover right now plugin sources.
I've mailed Andrey. I'll keep you informed.
Thanks a lot for helping!
Zigor
#18 Опубликовано: 29.01.2020 12:12:55
eswte
eswte
Hi I have the same problem with the Beam Analysis, have you got some answer?
#19 Опубликовано: 05.02.2020 04:11:36
Группа: Super Administrator
Hello.
Sources of Beam Analysis Utility Functions stored on SMath server but author of a plug-in asked not to share them.
Several days ago I've got permissions to fix an issue.
Plug-in functionality restored now. Tested ok with all available sample worksheets.
New version of a plug-in available using Extensions Manager.
Вячеслав Мезенцев 05.02.2020 05:17:00, sergio 05.02.2020 05:33:00, Martin_B 05.02.2020 07:10:00
#20 Опубликовано: 05.02.2020 06:35:03
Dear Andrey,
I've just download the plugin and check the SMath sheet.
I've only performed few tests, but it's working perfectly.
Thank you so much for your help and effort. Really.
Best regards!
Zigor
