Dynamic structural analysis
Dynamic structural analysis - Сообщения
#1 Опубликовано: 19.06.2024 19:09:51
pierre
pierre
2 сообщений из 17 понравились пользователям.
Hello to whole community,
I am working on a spreadsheet to calculate the response of a cantilever beam VIA a simple F.E.M solver.
I would like to find a solution to modify the part in yellow in the linked spreadsheet, as i dont like its presentation (string and var manipulation).
Modal analysis.sm (85 КиБ) скачан 80 раз(а).
Please dont focus on the presentation, it is still an ongoing work
However, i would be glad, if any mistake or optimisation (not liked to my question) is raised.
Thank you
#2 Опубликовано: 22.06.2024 06:45:52
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. This could be an option.
Modal analysis.sm (88 КиБ) скачан 73 раз(а).
ioan92 22.06.2024 16:32:00, Вячеслав Мезенцев 24.06.2024 01:32:00
#3 Опубликовано: 23.06.2024 02:47:01
1402 сообщений из 1708 понравились пользователям.
Sometimes I don't understand how it works anymore. The symbolic form of ODE was implemented for simpler expressions. It surprises me that this form of notation calculates anything.
#4 Опубликовано: 24.06.2024 15:29:53
pierre
pierre
Thank you Alvaro for your answer.
That cleaner
Another point is: I dont get why i can't use the diff(f,x,i) function in this specific case. Is it due to some way diff function and ' are coded?
Pierre
#5 Опубликовано: 30.06.2024 05:27:35
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Another point is: I dont get why i can't use the diff(f,x,i) function in this specific case. Is it due to some way diff function and ' are coded? ...
Hi. I don't know the internals of the Viacheslav plugin. But, in any case, you can see how difficult it is to describe the initials conditions with the diff notation in other languages, like maple or mathematica, checking the help of dsolve functions.
BTW, the plugin looks like a very powerful tool. For instance, in this file you can find how to solve your system with the classical D(t,x) runge kutta notation.
Modal analysis.sm (102 КиБ) скачан 76 раз(а).
I guess that the plugin can handle your system because it is lineal and uncoupled. You can see a try to use the mathcad block for solving hard coupled systems at the end of the first post of the Mathcad toolbox, https://en.smath.com/forum/yaf_postst726_Mathcad-Toolbox.aspx , in the files RKA.
