1 страниц (7 вхождений)
Double Integration using ode solvers - Сообщения
#1 Опубликовано: 04.06.2020 01:40:08
Hi. This worksheet shows how to use an ode solver for evaluating a double integral over the region between two functions.
DoubleIntegralRK.sm (42 КиБ) скачан 120 раз(а).
DoubleIntegralRK.pdf (219 КиБ) скачан 125 раз(а).
#2 Опубликовано: 07.06.2020 13:21:46
Thanks Alvaro for your example.
Can the change of variable be put in the procedure definition?
Physics is like sex. Sure, it may give some practical results, but that’s not why we do it. (R. Feynman)
#3 Опубликовано: 07.06.2020 19:50:25
WroteCan the change of variable be put in the procedure definition,?
Like this: yes, just opposite plot.
Double Switch [x, L].sm (6 КиБ) скачан 71 раз(а).
#4 Опубликовано: 17.06.2020 20:21:22
Hi. This is the double integral using Gauss Legendre quadrature.
GaussLegendreQuadrature.sm (60 КиБ) скачан 82 раз(а).
GaussLegendreQuadrature.pdf (160 КиБ) скачан 80 раз(а).
Yes.
DoubleIntegralSteelCat.sm (47 КиБ) скачан 86 раз(а).
DoubleIntegralSteelCat.pdf (105 КиБ) скачан 68 раз(а).
Wrote...
Yes.
#5 Опубликовано: 18.06.2020 11:26:19
Keisan has longer Legendre than 64, but couldn't copy/paste ?
From other source: 63, 64.
Integrate Legendre [ Wr 24 ].sm (28 КиБ) скачан 82 раз(а).
#6 Опубликовано: 18.06.2020 21:35:42
WroteKeisan has longer Legendre than 64, but couldn't copy/paste ?
Hi Jean. Yes, can copy and paste. Do that first into excel, and from there to the small SMathMatrixEditor and finally paste in SMath.
In the attached Laguerre and Legendre coeffs for the Gauss method.
DoubleIntegralJean.sm (25 КиБ) скачан 79 раз(а).
DoubleIntegralJean.pdf (45 КиБ) скачан 89 раз(а).
#7 Опубликовано: 20.06.2020 07:39:28
WroteHi Jean. Yes, can copy and paste.
Thanks, Amigo !
Новые сообщения
Нет новых сообщений
