Insert a row into an existing Matrix
Insert a row into an existing Matrix - Best way to insert a row / col into matrix - Сообщения
#1 Опубликовано: 21.03.2015 13:27:34
Ryan Freund
Ryan Freund
19 сообщений из 339 понравились пользователям.
What is the "best" way to insert a row into an existing matrix.
Say I am looping through a matrix and I want to insert a row (or column) of elements because of some other criteria. Then continue to loop through the matrix, adding rows when required by the conditions set. What is the best way to do this?
Thanks
#2 Опубликовано: 22.03.2015 14:31:34
You can try using stack() and submatrix() or with the Linq extension
