how to know the name of the variable
how to know the name of the variable - Сообщения
#1 Опубликовано: 27.02.2017 01:44:02
Kross
Kross
0 сообщений из 10 понравились пользователям.
for example
Count = 5
I can get the type of the variable
GetType(Count)="number"
I can get the value as a string
var2str(Count)="5"
I can even get a description of the variable
description(Count)="TestDescription"
I need to get the variable name "Count" as a string
With best wishes
#2 Опубликовано: 27.02.2017 06:42:41
Hello Kross,
You can't. If Count is defined (IsDefined(Count)=1), his value is replaced before being passed as argument in any function, hence the name cannot be retrieved. Why you need this? Maybe we can help you to find an alternative way to do the same or a similar task.
#3 Опубликовано: 27.02.2017 08:35:21
Kross
Kross
Hello Davide!
For my program StandardProject
(see the topic in Extensions)
For data exchange
the user generates a matrix
In the columns which
1 column - the name of the variable as a string
2 column - variable value as double
3 column - description as a string
to simplify and reduce errors
I was planning to write a function
which input received the list of variables
and the output was formed by the above matrix
With best wishes!
P.s.
if you're interested as implemented
watch the video
https://yadi.sk/i/GT_K4LXm3EhvAq
the full set of videos
https://yadi.sk/d/0aXk5NGQ3EhvUo
#4 Опубликовано: 27.02.2017 10:15:41
1402 сообщений из 1708 понравились пользователям.
Теоретически это можно сделать при помощи компонента Script, т.е. можно написать функцию на c#, которая возвращала бы нужную вам матрицу, перебрав все определения в документе. Практически же не знаю заработает это или нет, давно не пробовал компонент в работе.
#5 Опубликовано: 27.02.2017 11:27:52
I don't understand the request .
Inst_Colebrook Pipe Data.sm (60 КиБ) скачан 83 раз(а).
#6 Опубликовано: 27.02.2017 12:37:34
unfortunately this won't work; once passed through the function even descriptions will be lost (because the values are passed on evaluation, inside the function nothing is known but the values).
My suggestion is to create a function f(name,description,value) to create your matrix; function can be extended to 3 lists using vectorize() (or built directly to handle vectors). (or you can try to follow the hint given by uni).
#7 Опубликовано: 27.02.2017 13:06:13
Krid
Krid
0 сообщений из 16 понравились пользователям.
Thank you, Davide!
I also think that use the method proposed uni
To uni
but I can't understand how to write scripts
I propose to start with the basics
from a script to get Smath Studio any value
while it turns out to show only variables in the debug panel (the output window)
К Вячеславу
пока не могу понять как писать скрипты
предлагаю начать с азов
как из скрипта получить в Smath Studio любое значение
пока получается показать переменные только в панели отладки (окно вывода)
#8 Опубликовано: 27.02.2017 15:12:31
В скрипте есть доступ к объекту store и его методам. Насколько я помню, там есть метод AddDefinition(), с помощью которого можно добавить определение в текущий документ. То есть можно определить переменную, которой фактически нет в документе. Так работает функция include(), которая динамически добавляет определения в документ. Вы можете создать любое выражение и оно будет доступно ниже компонента Скрипт.
Проблема в том, что нужно очень точно представлять результат, чтобы описать алгоритм в скрипте. Для этого лучше сначала написать функцию в виде дополнения, отладить её, а потом поместить в скрипт. Поэтому пользоваться этим инструментом полноценно пока могут лишь разработчики дополнений, которые знакомы с документацией.
Я попробую набросать что-нибудь работающее.
#9 Опубликовано: 28.02.2017 01:50:23
Kross
Kross
Спасибо за содействие!
Буду очень признателен.
#10 Опубликовано: 28.02.2017 14:13:48
Just for curiosity and without any insight into real plugin-coding: Isn't the programmatic representation of the expressions as required in the script region that what the "Expression -> terms" dialog in the Development tools produces?
Is there a need to change the values for "List name" and "Array name"?
#11 Опубликовано: 28.02.2017 14:34:10
There are several ways how to use Script region.
Example 1.
try
    TMatrix m = new TMatrix( new TNumber[ 1, 3 ] );
    m.unit.SetValue( ( TNumber ) 1, new long[] { 0, 0 } );
    m.unit.SetValue( ( TNumber ) 2, new long[] { 0, 1 } );
    m.unit.SetValue( ( TNumber ) new TDouble( "\"Text\"" ), new long[] { 0, 2 } );
    store.AddDefinition( "out", m.ToTerms(), new Term[0] );
catch ( Exception ex )
    store.TraceData( ex.Message );
#12 Опубликовано: 28.02.2017 14:54:19
frapuano
frapuano
13 сообщений из 115 понравились пользователям.
Example 1.
try
...it is quite sad/frustrating not to understand better its usage ...just to organize to give it a try.
Franco
#13 Опубликовано: 01.03.2017 05:32:40
Kross
Kross
To uni
it's great
how do I output the variable in the field Smath Studio - understand
Question
1. how to get a specific variable from Smath Studio
2. is it possible to imagine a script as a function Smath Studio
for the subsequent call as a "normal" function Smath Studio
Перевод
это отлично
как вывести переменную в поле Smath Studio - понял
Вопрос
1. как получить конкретную переменную из Smath Studio
2. можно ли скрипт представить в виде функции Smath Studio
для последующего вызова как обычной функции Smath Studio
#14 Опубликовано: 01.03.2017 07:03:09
Example 2. How to get definition by name
try
    string varname = "a";
    // System.Collections.Generic пока не подключена, поэтому используем полное имя класса.
    // Переменная store не содержит публичного метода или свойства для доступа к коллекции определений,
    // поэтому создадим список "вручную". Со списком работать удобнее, чем с массивом.
    System.Collections.Generic.List<Definition> list = new System.Collections.Generic.List<Definition>();
    for ( int n = 0; n < store.Count; n++ ) list.Add( store[ n ] );
    // Функция условия для поиска определения.
    Predicate< Definition > cond = delegate( Definition x )
        // Если имя определения (переменной) равно varname.
        return x.Name.Equals( varname );
    // Метод Find ищет первый элемент, который удовлетворяет условию.
    Definition def = list.Find( cond );
    // Если элемент найден, то что-нибудь делаем.
    store.TraceData( varname + ( def != null ? " " : " not " ) + "found" );
    if ( def != null )
        TMatrix m = new TMatrix( new TNumber[ 2, 3 ] );
        m.unit.SetValue( ( TNumber ) new TDouble( "\"name\"" ), new long[] { 0, 0 } );
        m.unit.SetValue( ( TNumber ) new TDouble( "\"descr\"" ), new long[] { 0, 1 } );
        m.unit.SetValue( ( TNumber ) new TDouble( "\"value\"" ), new long[] { 0, 2 } );
        m.unit.SetValue( ( TNumber ) new TDouble( "\"" + def.Name + "\"" ), new long[] { 1, 0 } );
        m.unit.SetValue( ( TNumber ) new TDouble( "\"" + def.Description + "\"" ), new long[] { 1, 1 } );
        TNumber value = SMath.Math.Numeric.Expression.Calculate( def.Result, store );
        m.unit.SetValue( value, new long[] { 1, 2 } );
        Definition res = new Definition( "out", m.ToTerms(), new Term[ 0 ] );
        store.AddDefinition( res );
#15 Опубликовано: 01.03.2017 07:05:14
To uni
it's great
Question
Перевод
это отлично
Вопрос
2. Как функцию представить нельзя.
П.С. Теоретически можно написать дополнение, в котором можно использовать написанную функцию и потом вызывать её многократно как стороннюю. Я бы мог даже добавить кнопку в компоненте Скрипт, по которой формировалась сборка, но это всё сложно и целая эпопея.
#16 Опубликовано: 01.03.2017 07:43:44
#17 Опубликовано: 01.03.2017 08:48:42
Kross
Kross
То uni
Возникли проблемы
при использовании Лист.exe файл - исполняемый
1. Не обновляется поле из out переменной (выходной)
2. При перемещения тела скрипта в Область и последующим скрытием Области
при запуске Лист.exe файл - появляется сообщение - No 'Tech.CodeGenaration.dll' found in 'Лист'.
#18 Опубликовано: 01.03.2017 09:13:26
Kross
Kross
here's what you need to in the end
#19 Опубликовано: 01.03.2017 09:26:19
Я не знаю как пересчитать лист в exe версии. Для работы нужно скопировать в папку с exe-файлом следующие сборки:
Из папки с плагином (%user%\Application Data\SMath\extensions\plugins\20ad815b-bc5e-487d-9258-57fde2ac6de8\0.1.5997.41919\):
IronPython.dll
IronPython.Modules.dll
Microsoft.Dynamic.dll
Microsoft.Scripting.dll
Microsoft.Scripting.Core.dll
Microsoft.Scripting.Debugging.dll
Microsoft.Scripting.ExtensionAttribute.dll
Tech.CodeGeneration.dll
Из места установки программы:
SMath.Controls.dll
SMath.Manager.dll
SMath.Math.Numeric.dll
SMath.Math.Symbolic.dll
Вообще, вам лучше научиться писать плагины самому, тогда не нужно будет искать других путей. Ваша задача не решаема стандартными средствами SMath Studio.
#20 Опубликовано: 01.03.2017 13:28:53
Krid
Krid
Все ясно,
Спасибо!
Буду разбираться
с написанием плагина!
