How to display string element of the matrix in Smath Viewer?
How to display string element of the matrix in Smath Viewer? - Сообщения
#1 Опубликовано: 29.06.2018 08:53:06
Bartlomiej
Bartlomiej
I have a question if it's possible to display the string part of a matrix in *.exe file created from a Smath file?
Screenshot of issue
Tried the var2string function, but after changing the string value via exe file, it reads function argument name (a) instead of it's value.
Is there some kind of workaround for this issue?
#2 Опубликовано: 29.06.2018 10:37:31
Arie
Arie
93 сообщений из 285 понравились пользователям.
It would help if you post the original .sm file.
I'm not exactly sure what you are trying to do. Are you trying to assign a value to a variable name defined in a?
If so you can do something like this: https://en.smath.info/forum/yaf_postsm36117_New-variable-programmatically--also--Solving-under-over-defined-system-of-linear-eqautions.aspx#post36117
As far as getting that dynamically created variable name to display on the left as an actual variable name, I'm not sure if that's possible.
#3 Опубликовано: 29.06.2018 10:42:57
Bartlomiej
Bartlomiej
In smath it's defined as:
a:="sample string"
a="sample string"
And if I change the string, sheet recalculates and shows a value as the new string. I wanted to achieve this functionality in smath viewer in exe file for creating additional info page on my docs, like project name and so on.
#4 Опубликовано: 29.06.2018 11:27:39
Arie
Arie
Make sure you hit enter/return key after entering value.
Edit: You may have found a bug. This kind of functionality works great with numeric values but not with strings. I've tried with different optimizations as well to no avail.
I'm not sure it's ever worked. I now SMath Viewer is still a work in progress so feel free to add bug entry.
#5 Опубликовано: 29.06.2018 14:33:35
CBG
CBG
77 сообщений из 312 понравились пользователям.
Screenshot of issue
Hello Barmin
The function you are looking for was previously available in previous versions of smath, such as version 5737.
I do not know why they disabled it. Here I put an example in that version.
Test_string_5737.zip (359 КиБ) скачан 83 раз(а).
Carlos
#6 Опубликовано: 01.07.2018 13:56:27
Bartlomiej
Bartlomiej
Seems it's a bug then. Thanks for info.
#7 Опубликовано: 02.07.2018 11:07:17
Can't reproduce
hallo.sm (2 КиБ) скачан 74 раз(а).
hallo.zip (482 КиБ) скачан 67 раз(а).
#8 Опубликовано: 02.07.2018 11:11:51
Arie
Arie
Martin,
Once the Viewer is running try to change the value of Hallo and notice if it doesn't update in the second box.
#9 Опубликовано: 02.07.2018 22:58:56
CBG
CBG
#10 Опубликовано: 03.07.2018 04:58:49
For me it works. Yet I have to press enter to forward the changes in the input box.
#11 Опубликовано: 03.07.2018 06:14:27
For me it will change the numerical variable but not the string one (with return pressing, of course).
before
after
#12 Опубликовано: 05.03.2021 15:38:37
Wesly Centerwall
Wesly Centerwall
26 сообщений из 156 понравились пользователям.
So what was the end result of this topic?
Why is the ability to modify text string entries disabled in the viewer?
#13 Опубликовано: 11.03.2021 21:34:26
Wesly Centerwall
Wesly Centerwall
This issue has now been resolved in the latest update.
#14 Опубликовано: 11.03.2021 22:55:14
CBG
CBG
You are right, the text change in the variables still does not work.
Carlos
#15 Опубликовано: 11.03.2021 23:00:50
Wesly Centerwall
Wesly Centerwall
Please take a look at this topic. You will need the latest nightly build to have functionality.
#16 Опубликовано: 12.03.2021 14:17:50
CBG
CBG
I did a test with the latest version of Smath Studio and the Viewer and it does not work
Carlos
#17 Опубликовано: 12.03.2021 15:03:32
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Carlos
Hi. Carlos it's right. I guess that there are an issue with the automatic update within the nightly build which seems to be now appVersion(4)="0.99.7739.40423"@# but previously I have appVersion(4)="0.99.7739.41xxx "@# or something like that.
#18 Опубликовано: 12.03.2021 22:08:51
Wesly Centerwall
Wesly Centerwall
Seems to be working just fine for me.
99.7739.40423_Test_exe.zip (571 КиБ) скачан 52 раз(а).
Good Luck!
#19 Опубликовано: 12.03.2021 22:12:22
Wesly Centerwall
Wesly Centerwall
I'm using 64bit Win10 Enterprise by the way. Maybe it matters?
Alvaro Diaz Falconi 12.03.2021 23:30:00
#20 Опубликовано: 12.03.2021 23:29:48
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Me too, but 32 bits. I'm reinstall SMath and now works fine.
Thanks.
