"on error" test image rotate
"on error" test image rotate - "on error" test image rotate - Сообщения
#1 Опубликовано: 16.04.2016 14:42:32
Hello Mike,
If you can make it work at the "on error" that Smath 5346 does not have
the Smath community will heritate a nice piece of work that I heritated
from Paul W. [Mathcad 11 Collaboratory]. If there is a way to make it
work in 5346, I will most appreciate. The R, G, B are all in the collapsed
areas, nothing to download. The coding stops at the empty place holders.
Thanks for your kindly cooperation, good luck.
Rotate Image.sm (431 КиБ) скачан 75 раз(а).
#2 Опубликовано: 16.04.2016 19:50:06
Mike Kaganski
Mike Kaganski
rotate() tries to get fourth col of a matrix having only two cols:
trace.sm (100 КиБ) скачан 71 раз(а).
Actually, I didn't try to understand the algo yet, so I have no clue how to improve it.
Edit:
in the original algo, there's no line like
s:augment(col(s,2),col(s,4))
Removing it gives another error: j becomes -14, and this index isn't OK as a matrix col.
Edit 2: here it is, should work for 5346: Rotate Image.sm (407 КиБ) скачан 77 раз(а). (updated for 2x speed using eval()).
Edit: and here is the colored version (great thanks to Alex Melnik): Rotate Image+color.sm (414 КиБ) скачан 74 раз(а).
С уважением, Михаил Каганский
