Validating Input String
Validating Input String - Сообщения
#1 Опубликовано: 06.12.2023 01:30:03
Wesly Centerwall
Wesly Centerwall
26 сообщений из 156 понравились пользователям.
What would be the best way to validate an input string in order to ensure it is a number and does not include any other characters?
Keep in mind that I'm referring to actual input in string form that is then converted into a number via str2num().
#2 Опубликовано: 06.12.2023 12:56:39
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. This could be a way for positive numbers.
check.sm (4 КиБ) скачан 43 раз(а).
#3 Опубликовано: 06.12.2023 18:12:00
Here is a less compact solution, can be adapted to accept different characters.
(Positive/negative values can be allowed with an additional condition on the first character)
test_input.sm (12 КиБ) скачан 55 раз(а).
sergio 07.12.2023 16:48:00, Wesly Centerwall 08.12.2023 05:53:00
#4 Опубликовано: 06.12.2023 21:54:14
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Signed numbers allowed. Also, compared with str2num results.
check.sm (12 КиБ) скачан 54 раз(а).
Wesly Centerwall 08.12.2023 05:53:00, sergio 07.12.2023 16:48:00
#5 Опубликовано: 07.12.2023 03:16:07
Near identical to Davide, this is how I would do it.
At least this is what I have done in QBasic long ago.
IsNumber.sm (7 КиБ) скачан 55 раз(а).
NDTM Amarasekera 08.12.2023 09:50:00, sergio 07.12.2023 16:48:00, Oscar Campo 07.12.2023 17:26:00, Wesly Centerwall 08.12.2023 05:53:00
#6 Опубликовано: 08.12.2023 05:52:28
Wesly Centerwall
Wesly Centerwall
Thanks guys for the input. All very insightful and useful!
#7 Опубликовано: 09.12.2023 03:55:37
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. Parenthesis added. Notice that the plus/minus sign must to be only at the first's places, but with parenthesis it is not more true. And it looks like SMath's str2num have a bug: str2num(" ((1)" ) is wrong.
Check.sm (21 КиБ) скачан 52 раз(а).
