Stable: SMath Studio 0.99.6622 (17 February 2018)
Stable: SMath Studio 0.99.6622 (17 February 2018) - Сообщения
#1 Опубликовано: 17.02.2018 10:06:18
2270 сообщений из 3734 понравились пользователям.
Группа: Super Administrator
List of changes(between 0.99.6617 and 0.99.6622 versions)
Download
SMathStudioDesktop.0_99_6622.Mono.tar.gz (1 МиБ) скачан 2224 раз(а).
SMathStudioDesktop.0_99_6622.Setup.msi (2 МиБ) скачан 18891 раз(а).
System requirements
  • Desktop (Windows):
  • Desktop (Linux):
Interface languages (37 languages)
  • [ARA] Arabic / العربي
  • [BEL] Belarusian / Беларуская
  • [BUL] Bulgarian / Български
  • [CAT] Catalan / Català
  • [CZE] Czech / Čeština
  • [DAN] Danish / Dansk
  • [DUT] Dutch / Nederlands
  • [ENG] English / English
  • [FAS] Persian / فارسی
  • [FIN] Finnish / Suomi
  • [FRE] French / Français
  • [GER] German / Deutsch
  • [GRE] Greek / Ελληνικά
  • [HEB] Hebrew / עברית
  • [HUN] Hungarian / Magyar
  • [IND] Indonesian / Bahasa Indonesia
  • [ITA] Italian / Italiano
  • [JPN] Japanese / 日本語
  • [KOR] Korean / 한국어
  • [LAV] Latvian / Latviešu
  • [LTH] Lithuanian / Lietuvių
  • [NOR] Norwegian / Norsk
  • [POL] Polish / Polski
  • [RON] Romanian / Română
  • [RUS] Russian / Русский
  • [SCC] Serbian (Latin) / Srpski
  • [SCR] Croatian / Hrvatski
  • [SLK] Slovak / Slovenčina
  • [SPA] Spanish / Español
  • [SRP] Serbian (Cyrillic) / Српски
  • [SWE] Swedish / Svenska
  • [TUR] Turkish / Türkçe
  • [UKR] Ukrainian / Українська
Tutorial
  • SMathPrimer.pdf (Date: 11.11.2011. File size: 2.06MB) - to open in Adobe Acrobat Reader
Other files
SMath Studio icons () of all available sizes (16x16, 24x24, 32x32, 48x48, 64x64, 96x96, 128x128, 256x256) in PNG format.
10 пользователям понравился этот пост
Василий Николаевич Храмушин 03.03.2018 06:07:00, sergio 17.02.2018 12:11:00, Radovan Omorjan 17.02.2018 12:42:00, IVR 17.02.2018 14:14:00, Вячеслав Мезенцев 17.02.2018 14:21:00, Martin_B 17.02.2018 15:42:00, Davide Carpi 17.02.2018 19:43:00, Denis Nikitin 20.02.2018 03:37:00, NDTM Amarasekera 17.02.2018 10:25:00, Igor Skarine 17.02.2018 13:08:00
#2 Опубликовано: 17.02.2018 12:48:08
SMath Studio in the Cloud updated to use SMath Core 0.99.6622. Both features: equations breaking and inserting special symbols into equations - are now supported in Cloud.
Igor Skarine 17.02.2018 13:06:00, Davide Carpi 17.02.2018 19:43:00, frapuano 17.02.2018 15:24:00
#3 Опубликовано: 19.02.2018 14:43:10
Almost forgot to highlight the following important change done in this release:
errors_behavior_1.sm (4 КиБ) скачан 106 раз(а).
Вячеслав Мезенцев 20.02.2018 01:24:00, sergio 19.02.2018 17:15:00, Davide Carpi 19.02.2018 20:36:00
#4 Опубликовано: 06.03.2018 13:38:59
Doug Schickler
Doug Schickler
Hi Andrey
Very surprised that an error popped up in the latest build. Maybe also the one before, not sure.
For your info, here is the S' definition
It seems that somehow these last two builds cannot find a value of the matrix coordinates indicated. It worked fine in .6484 from October, which I have gone back to. I can send you the file, but I would prefer to do so privately.
Love this program
Doug Schickler
#5 Опубликовано: 06.03.2018 15:11:13
Hello.
Please send a worksheet to me so I could reproduce and fix this issue. E-mail is specifield into About dialog of SMath Studio.
Thank you for the report!
#6 Опубликовано: 07.03.2018 23:59:51
It seems that somehow these last two builds cannot find a value of the matrix coordinates indicated.It worked fine in .6484 from October, which I have gone back to.I can send you the file, but I would prefer to do so privately.
That it worked 6484, I doubt as it shows incorrectly dressed.
If you had a result => most probably erroneous.
On the setup "rotation*matrix", Smath [4356, 6179] displays an error message.
The rule Matrix*Rotation is universal, not commutative.
UnknownConfidential.sm (202 КиБ) скачан 104 раз(а).
Rotate Breather [4 Orientations].sm (1001 КиБ) скачан 108 раз(а).
#7 Опубликовано: 02.04.2018 17:25:41
RickH
RickH
I have noticed that if I open a .sm file which has file properties set to "read only", the program will crash if I press the "save" button. It would be nice if it instead prompted to "save-as" in that scenario, or just notify the user that the file is read only so the user can then perform a save-as instead. This is on Windows 7. Thanks.
#8 Опубликовано: 03.04.2018 06:08:05
Already fixed in SS 0.98.6626 and later nightly builds, will be part of next stable release.
