Stable: SMath Studio 1.0.8151 (26 April 2022) - Сообщения
List of changes(between 0.99.7921 and 1.0.8151 versions)
Улучшения
- SMath Studio splitted to SMath Solver & SMath Writer;
- Application icons and splash screens updated;
- Separate set of icons created for supported file formats;
- *.smw file type introduced for SMath Writer documents;
- Autodetection of units input implemented in TextRegion;
- Description of the functions inside Insert Function made formattable;
- Beta version of the calculation service implemented;
- Added support for offline activation (QRCode + manual) to log in into SMath Account even without Internet connection.
Исправления
- Fixed critical issue happens on snippet adding;
- Fixed error on file Save happens in some cases (related to dependencies list).
Разное
- Cursor in MathRegion is now hidden if selection is shown;
- Refactoring;
- Russian End User License Agreement updated;
- Donations dialog removed;
- SMath Writer icons not created by the installer (application is still available in the installation directory and file types associations are still active);
- SMath Studio installer UI updated;
- Interface translations updated.
Download
SMathStudioDesktop.1_0_8151.Mono.tar.gz (1 МиБ) скачан 16998 раз(а).
SMathStudioDesktop.1_0_8151.Setup.msi (2 МиБ) скачан 50781 раз(а).
- Desktop (Windows):
Framework: .NET Framework 2.0 or higher - Desktop (Linux):
- [ARA] Arabic / العربي
- [BEL] Belarusian / Беларуская
- [BUL] Bulgarian / Български
- [CAT] Catalan / Català
- [CHS] Chinese (Simplified) / 简体中文
- [CHT] Chinese (Traditional) / 簡體中文
- [CPP] Portuguese (Brazil) / Brazil (Português)
- [CZE] Czech / Čeština
- [DAN] Danish / Dansk
- [DUT] Dutch / Nederlands
- [ENG] English / English
- [FAS] Persian / فارسی
- [FIN] Finnish / Suomi
- [FRE] French / Français
- [GER] German / Deutsch
- [GRE] Greek / Ελληνικά
- [HEB] Hebrew / עברית
- [HUN] Hungarian / Magyar
- [IND] Indonesian / Bahasa Indonesia
- [ITA] Italian / Italiano
- [JPN] Japanese / 日本語
- [KOR] Korean / 한국어
- [LAV] Latvian / Latviešu
- [LTH] Lithuanian / Lietuvių
- [NOR] Norwegian / Norsk
- [POL] Polish / Polski
- [POR] Portuguese / Português
- [RON] Romanian / Română
- [RUS] Russian / Русский
- [SCC] Serbian (Latin) / Srpski
- [SCR] Croatian / Hrvatski
- [SLK] Slovak / Slovenčina
- [SPA] Spanish / Español
- [SRP] Serbian (Cyrillic) / Српски
- [SWE] Swedish / Svenska
- [TUR] Turkish / Türkçe
- [UKR] Ukrainian / Українська
SMathPrimer.pdf (Date: 11.11.2011. File size: 2.06MB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.Article.Eng.pdf (Date: 23.09.2009. File size: 828.96KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.IOFiles.Article.Eng.pdf (Date: 27.09.2009. File size: 453.24KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.NumericFunctions.Article.Eng.pdf (Date: 18.10.2009. File size: 622.45KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.Programming.Article.Eng.pdf (Date: 18.10.2009. File size: 411.74KB) - to open in Adobe Acrobat Reader
SMath Studio icons (
SMathStudio.Icons.zip (Date: 12.04.2010. Size: 63.74KB)
One question: What means "Beta version of the calculation service implemented"?
We all hope you and your team are safe and doing well. Thank you for continuing to update the program. Not sure if this is a bug, but I have NOT been on SMath in a while. I tend to use the portable version. Today, I ran the update (version 0.99.7921). and nothing. No updates. I decided to see what I've missed on the forums and HELLO version 1.0.8151. Essentially, the update from 0.99.XXX is not seeing the new 1.0.XXX version. Be blessed!
I am running Windows 10 Pro 21H2, compilation 19044.1645
Any hint how to solve?
List of changes(between 1.0.8206 and 1.0.8238 versions)
Улучшения
- if(..) function extended to support any number of arguments more or equal to 2;
- Approximately Equal operator implemented (Options dialog extended with an appropriate setting; button added to the Boolean toolbox);
- Defined Integral supports units now;
- Rendering of the text improved in program dialogs;
- Electron-volt (k, M, G, T) unit added;
- Sleep function added allows to suspends the current thread for the specified amount of time specified in milliseconds;
- Proxy settings implemented;
- Handling of the conversion related exceptions significantly improved;
- Word wrapping improved for TextRegion;
- Dynamic assistance list rendering improved;
- Description added for Clear(..) function;
- Added possibility to login into Account or retreive Account related information without UI using command line (-a cmd argument to get info and in combination with -o to perform login: "Username=XXXX;Password=YYYY").
Исправления
- Numeric calculations with units corrected in cases when final result is equal to zero;
- Unhandled exception fixed happened in some cases when using DEL in MathRegion;
- Support for trace(...) with replacements restored;
- Approximately Equal operator corrected to work with 0;
- Miss-spelling fixed.
Разное
- Startup of Desktop version is made faster in the environments where access to printer is slow;
- High DPI support improved;
- Displaying of the previews improved in Insert Function dialog;
- Offline login logic corrected;
- Settings dialog refactoring;
- SMath LLC code certificate issued and included into repository;
- Checkbox for service installation removed from MSI wizard;
- Interface translations updated;
- Refactoring.
Download
SMathStudioAndroid.1_0_8238.arm64-v8a.apk (12 МиБ) скачан 3550 раз(а).
SMathStudioAndroid.1_0_8238.armeabi-v7a.apk (14 МиБ) скачан 2318 раз(а).
SMathStudioAndroid.1_0_8238.x86_64.apk (13 МиБ) скачан 2211 раз(а).
SMathStudioAndroid.1_0_8238.x86.apk (13 МиБ) скачан 1995 раз(а).
SMathStudioDesktop.1_0_8238.Mono.tar.gz (1 МиБ) скачан 4205 раз(а).
SMathStudioDesktop.1_0_8238.Setup.msi (3 МиБ) скачан 12458 раз(а).
SMathStudioDesktop.1_0_8238.x86_64.astra-orel.glibc2.24.AppImage (10 МиБ) скачан 2226 раз(а).
SMathStudioDesktop.1_0_8238.x86_64.ubuntu-22_04.glibc2.35.AppImage (12 МиБ) скачан 2346 раз(а).
I just installed this version and I'm wondering, how does if-else work now? With earlier versions the statements were filled automatically (which was annoying if only if-statement was needed), but now it only fills for if-statement, and I cannot seem to figure out how to get the else-statement.
WroteHi!
Please read this: https://en.smath.com/forum/yaf_postst23150_if------not-correct-shown-in-Win11.aspx
Cool, else-if too, thanks! The solution did not seem to be documented or I missed it. I was looking for the little black square that expands matrices and similar.
Wrote(which was annoying if only if-statement was needed)
IMHO, I have never seen only if as it is not Bolean.
if/else ... if/otherwise are generally not interchangeable.
In program if/else on strictly numeric branching.
if/otherwise is a scalar function for plotting, integrator, solving ...
Cheers ... Jean if you wish more.
WroteIn program if/else on strictly numeric branching.
Under construction ...
... if/else in program.
... if/otherwise scalar [plot, solve, integration ...]
Good reading ... Jean.
X_Y Bolean EXCLUSIVE...TREASURY.sm (105 КиБ) скачан 90 раз(а).
Updating from 1.0.8151 to 1.0.8238 broke background printing of smath document. I used to be able to copy paste the file onto one note page (for collaboration), right click on it and "insert as printout" (see screenshot). This functionality broke down with switch to 1.0.8238. I will stay at 1.0.8151 for now.
Cheers
Sasha
Новые сообщения
Нет новых сообщений
