Country flags
Country flags - x-yplot fill - Сообщения
#1 Опубликовано: 17.11.2024 17:24:11
With X-Y Plot plugin new fill feature, it is easier to make nice plots.
Let's make this a challenge, upload your country flag under this post.
Here is my country's flag totally accurate to our flag standard.
flag_tr.sm (9 КиБ) скачан 77 раз(а).
francesco rapuano 18.11.2024 14:42:00, Вячеслав Мезенцев 18.11.2024 15:52:00, Alvaro Diaz Falconi 19.11.2024 14:18:00
#2 Опубликовано: 18.11.2024 21:25:59
Oscar Campo
Oscar Campo
124 сообщений из 298 понравились пользователям.
Hi [USERLINK]overlord[/USERLINK]! Here is my contribution.
The flag design of my country is very simple, so I add some waves to make it more interesting.
flag_CO.sm (14 КиБ) скачан 61 раз(а).
[albumimg]1718[/albumimg]
Regards!!
overlord 18.11.2024 22:25:00
#3 Опубликовано: 18.11.2024 22:51:26
алексей
алексей
17 сообщений из 78 понравились пользователям.
#4 Опубликовано: 18.11.2024 23:06:56
1402 сообщений из 1708 понравились пользователям.
I like to approach things universally, so I found svg pictures of all the flags. All that's left is to implement their rendering. Then everyone will be happy.
#5 Опубликовано: 19.11.2024 00:38:37
Mo
Mo
0 сообщений из 34 понравились пользователям.
Hi, for some reason the flag is not filled as it is shown?
this is how it shows on my version now (V1.2 built 9018 dated 09-sep-2024)
this is the flag with no fill:
#6 Опубликовано: 19.11.2024 01:08:14
Oscar Campo
Oscar Campo
also, I noticed that the "properties source" in the formatting options is gone now, so how can we adjust the max/min and ticks by code?
Thanks
this is the old version where the "properties source" is shown
You must to update the X-Y Plot Plugin
#7 Опубликовано: 19.11.2024 04:25:25
Mo
Mo
Thanks, I just realised the plugin has changed.. I am reading through to see how to fix the old code.
#8 Опубликовано: 19.11.2024 14:23:11
Alvaro Diaz Falconi
Alvaro Diaz Falconi
992 сообщений из 1674 понравились пользователям.
Hi Overlord. My contribution too. If the flag is not too complicated you can try programming its path using SVG commands in SMath with this file (taken from here, but due to the bug with <, > and & it no longer works well). Or simply use the text with the SVG commands and display it in an image component:
svg_uy_flag.sm (299 КиБ) скачан 74 раз(а).
overlord 04.12.2024 15:25:00
#9 Опубликовано: 19.11.2024 17:55:55
Oscar Campo
Oscar Campo
Hi Alvaro,
I was checking your script "svg_starting.sm" and made a little function to deal with "<> bug". You can see here: svg_starting (fixed).sm (287 КиБ) скачан 80 раз(а).
Best wishes,
Oscar
Alvaro Diaz Falconi 20.11.2024 16:41:00, ioan92 19.11.2024 22:44:00
#10 Опубликовано: 20.11.2024 16:41:49
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi Alvaro, I was checking your script "svg_starting.sm" and made a little function to deal with "<> bug". You can see here: svg_starting (fixed).sm (287 КиБ) скачан 80 раз(а).
Hola Oscar. Gracias!
Un abrazo.
Oscar Campo 20.11.2024 16:45:00
#11 Опубликовано: 23.11.2024 03:58:01
⚜ Kenny Lemens, P.E. ᵂᴵ
74 сообщений из 164 понравились пользователям.
Greetings,
Here is my candidate:
Click to enlarge
2024-11-22_SMath_USA_Flag.sm (92 КиБ) скачан 77 раз(а).
May this be of Good Help;
overlord 29.11.2024 03:53:00
