1 страниц (7 вхождений)
Integration and use of matrices - Сообщения
#1 Опубликовано: 28.10.2011 22:50:35
I am starting to get used to using SMath Studio, however, I am having some problems, I have uploaded an SMath Studio file which can be downloaded at the following link which will show the two problems I am having. Would really appreciate some input on this please. Thanks.
https://files.warwick.ac.uk/muratali/files/Example.sm
Thanks
Thanks
#2 Опубликовано: 29.10.2011 01:25:17
Pay attention when using dot in the variable name ( z and z. are not the same - unfortunately, a common mistake). The nice thing about SMath is that when you click on the variable in a math region, then all the instances of the same variables will become gray - just use this please in order to see the mistakes of the kind like invisible dot at the end of a variable.
Please find the answer in the corrected example - Example corrected
#3 Опубликовано: 29.10.2011 17:49:35
Thanks Radovan, that really does help.
#4 Опубликовано: 05.11.2011 04:40:06
How did you do a double subscript el(z.eg.i) in the "Example corrected" worksheet above? Thanks.
#5 Опубликовано: 05.11.2011 08:04:51
It is the same like in Mathcad. The dot in the variable name will not be visible - but it will make so called "literate subscript". It is the part of a variable name. That is different than the el() function which gives the array subscript (row,collumn position in a Matrix). Therefore the variable you mentioned
[MATH=eng]el(z.eg,i)[/MATH]
has been obtained by typing z.eg[i or el(z.eg,i)
WroteHow did you do a double subscript el(z.eg.i) in the "Example corrected" worksheet above?
#6 Опубликовано: 05.11.2011 11:21:04
Thanks,
Really sorry, I seem to be having two problems, not sure how I can get round them in the most simple way using SMath. I have uploaded the SMath studio file at the following link
https://files.warwick.ac.uk/muratali/files/Queries_SMath_Studio.sm
#7 Опубликовано: 05.11.2011 12:42:25
Here is the corrected file Queries corr.
My input is in blue color.
I hope this is what you need.
Новые сообщения
Нет новых сообщений
