1 страниц (7 вхождений)
Removing units from a result / variable - Сообщения
#1 Опубликовано: 31.01.2020 08:10:12
Hi all!
Maybe this is a stupid question, but I'm just starting with SMath.
I searched also in forums but didn't find a similar topic..
I perform my calculations in SMath using always units, very interesting and useful. But now I need just the number, the value without units. What I do now is just dividing it by '1' and the unit XD
Any other method or function more professional? :P
Thanks a lot!
Zigor
Thanks a lot!
Zigor
#2 Опубликовано: 31.01.2020 08:33:28
WroteHi all!
In fact, this is the only professional way to do it, because this way you can control and display the unit to be used. Just suppressing the unit would force the reader to make assumptions on what unit has been used to derive the numerical value. The experienced reader knows that always base units are used (e.g. for plotting) but it is better to explicitly specify them.
#3 Опубликовано: 31.01.2020 09:02:40
Thanks, Martin..
It's exactly the way I work.
But now I want to export data to an Excel sheet, and afterwards to treat that data as numbers without unit (Excel works like that).. so instead removing the unit in Excel, I was just wondering if in SMath would be a function to do it before exporting
Best regards,
Zigor
Best regards,
Zigor
#4 Опубликовано: 31.01.2020 09:30:23
Assuming you have a table with columnwise uniform units, then the following approach provides full control:
exportdata.sm (4 КиБ) скачан 64 раз(а).
Alvaro Diaz Falconi 01.02.2020 16:59:00
#5 Опубликовано: 31.01.2020 11:51:27
WroteI perform my calculations in SMath using always units,
That is incoherent with unitless maths.
1. It can't be QA whereas the unit system sub-processes.
2. Advanced maths [symbolic, solvers ..] don't take units.
... I'm immune to "thunder" from contradictory comments !
Engineering formulas are already given in corresponding units [SI , ...]
#6 Опубликовано: 31.01.2020 12:07:07
WroteEngineering formulas are already given in corresponding units [SI , ...]
... or construct wrt the units you want.
... export table w/o header
Inst_Colebrook Pipe Data.sm (61 КиБ) скачан 81 раз(а).
#7 Опубликовано: 31.01.2020 13:00:29
Wrote... or construct wrt the units you want.
1. Vincenti is coded 'km' superb
2. Arc length is unary maths ... make it user c/w unit.
Angle Vincenty Earth Distance [Mike].sm (40 КиБ) скачан 69 раз(а).
Integrate Compendium_4 ArcLength Parabola-Cubic.sm (20 КиБ) скачан 69 раз(а).
Новые сообщения
Нет новых сообщений
