Matrix size defined by variables
Matrix size defined by variables - Сообщения
#1 Опубликовано: 23.03.2018 11:30:17
Rens
Rens
Does anyone know if it is possible to define a variable which will determine the size of a matrix. From where on the created matrix is again an input and not an output.
For exaple:
n:=1 (number of rows)
m:=3 (number of koloms)
creates a matrix of 1 kolom and 3 rows as below
y:= [* * *]
where the '*' are emty and can be spicified by the user.
Beste regards,
Rens Servais
#2 Опубликовано: 23.03.2018 11:57:07
Arie
Arie
93 сообщений из 285 понравились пользователям.
Check out this example.
Matrix.sm (7 КиБ) скачан 107 раз(а).
#3 Опубликовано: 23.03.2018 12:34:01
Both ways: empty and '0'
#4 Опубликовано: 23.03.2018 15:18:56
CBG
CBG
77 сообщений из 312 понравились пользователям.
Other solution
Carlos
#5 Опубликовано: 24.03.2018 04:47:24
Rens
Rens
Thanks Jean Giraud,
Your solution suits the best for me, but I can not reproduce it. See below. What do I do wrong?
Beste regards,
Rens
Matrix.sm (31 КиБ) скачан 80 раз(а).
#6 Опубликовано: 24.03.2018 07:13:25
1418 сообщений из 2874 понравились пользователям.
Do one of the following:
  • press CTRL+M
  • write mat(
  • write mat and press the tabulation key
  • on the right side of the windows, click on the first element of the Matrices toolbox
  • use the function dialog (press CTRL+E or choose the Insert > Function menu item or click on the fx symbol from the toolbar) choose the Matrix and vector group and search mat (click on whatever item and press m), then double click it or click on the insert button
    Файл не найден. Файл не найден.
Andrey Ivashov 24.03.2018 07:39:00, frapuano 24.03.2018 08:58:00
#7 Опубликовано: 25.03.2018 23:10:14
That will work for you. At this point, you can address any element.
The empty matrix has almost no use.
#8 Опубликовано: 25.03.2018 23:28:48
Plenty of matrix manipulation in there.
There are more and more, that should help.
Utilities Matrix Treasury_2 Copy.sm (109 КиБ) скачан 109 раз(а).
Utilities Matrix Treasury_0 Copy.sm (376 КиБ) скачан 107 раз(а).
Utilities Matrix Treasury_1 Copy.sm (372 КиБ) скачан 98 раз(а).
