1 страниц (5 вхождений)
case function order - Сообщения
#1 Опубликовано: 12.12.2019 09:41:20
Will the case function evaluate all the potentially true cases in it? There seams to be a feature where as soon as one case is evaluated as true then the output from that case is returned independent on weather following cases rule the first out.
im trying to construct a piecewise flow characteristic for a number of different applications where cases will be true dependant on the input. In certain situations the lower of the possibilities needs to be returned.
Smath case behave example.sm (18 КиБ) скачан 103 раз(а).
any thoughts?
any thoughts?
#2 Опубликовано: 12.12.2019 12:37:46
WroteWill the case function evaluate all the potentially true cases in it ?
Just by inspection of your document: answer is NO ... Why ?
1. define completely #≤# ... #≥# piecewise elements.
Smath does not forgive/forget.
2. If not plot ... zap units.
Come back as needed ... Jean.
Smath case behave example.sm (19 КиБ) скачан 87 раз(а).
#3 Опубликовано: 12.12.2019 13:13:00
WroteSmath does not forgive/forget.
Thanks Jean, this I am discovering!
The plots seam to work fine with the units - and its a good sense check for me.
Coming from MCD I was hoping that the case structure would work in the same way as a line form with ifs in (but no elses) and check each case in turn. I'll just have to be more careful about the relative importance / order of the cases.
#4 Опубликовано: 12.12.2019 16:12:33
WroteThanks Jean, this I am discovering!
Smath does not have the single line if MCD ... not yet coded.
Good it works with units.
Bolean is often a good candidate.
In some instances Smath will not complain incomplete <, >.
In other instances [I only know 1 in years], must be incomplete.
Cheers, welcome ... Jean.
#5 Опубликовано: 12.12.2019 16:53:49
Hi. This is a better way for use units, function and plots.
Smath case behave example.sm (20 КиБ) скачан 143 раз(а).
frapuano 12.12.2019 20:29:00
Новые сообщения
Нет новых сообщений
