Transpose
Transpose - Glitch in transpose with Smath - Сообщения
#1 Опубликовано: 15.04.2016 15:12:43
Ruben Sidranski
Ruben Sidranski
17 сообщений из 463 понравились пользователям.
See attached. Including file and screenshots. Looks like the second transpose of D is using the Debye moment definition! Getting rid of units, the transpose of D equals the transpose of Q
Transpose Bug.sm (7 КиБ) скачан 76 раз(а).
#2 Опубликовано: 15.04.2016 18:08:06
That's what I have explained before: maths are unitless.
Units is an associated math system, each procssing.
I can see Mathcad 15 was modified [after my war against units].
#3 Опубликовано: 15.04.2016 18:12:48
Ruben Sidranski
Ruben Sidranski
Did you see my last screen shot?
#4 Опубликовано: 15.04.2016 18:19:58
CBG
CBG
77 сообщений из 312 понравились пользователям.
For some reason , units outside the brackets of the vector, are causing the problem in the transposition of the vector
Transpose Bug_1.sm (15 КиБ) скачан 62 раз(а).
Transpose Bug.sm (15 КиБ) скачан 60 раз(а).
#5 Опубликовано: 15.04.2016 19:04:35
Mike Kaganski
Mike Kaganski
You keep "defining" *modified values* - like here: you try to "define" what "transposed Q" is.
This is what you actually do:
transpose(Q):mat(50,80,1,2)*'gal/'min
Don't you see what's going on? Yes, you simply override built-in transpose. Everything is correct.
С уважением, Михаил Каганский
#6 Опубликовано: 15.04.2016 21:32:36
Ruben Sidranski
Ruben Sidranski
In this case ... no, I did not notice the ":=" on the Transpose of Q (too fast for my own good!). I was having this happen on 5 other sheets ... This was a sample. I will check the other sheets to see if i did the same thing. Thanks for pointing that out
