1 страниц (8 вхождений)
ODE2 - Not a proper differential equation? - Сообщения
#1 Опубликовано: 07.10.2024 15:12:57
#2 Опубликовано: 07.10.2024 17:20:54
#3 Опубликовано: 07.10.2024 17:56:58
#4 Опубликовано: 07.10.2024 18:18:13
#5 Опубликовано: 07.10.2024 18:57:17
And there are also some approach using maxima engine/command?
#6 Опубликовано: 08.10.2024 15:11:16
WroteAnd there are also some approach using maxima engine/command?
Sure. Here is one using Maxima's desolve function and one using ODE.2 (without solving for the integration constants)
RLC.sm (23 КиБ) скачан 65 раз(а).
Feder-Masse.sm (23 КиБ) скачан 78 раз(а).
#7 Опубликовано: 09.10.2024 14:42:41
Martin, do you have an example for a third order differential equation on how to solve it? because ode2 is limited to second order differentia eq as far as I understood. And my previous question was on how to sollve a differential eq of order > 2 (3, 4, etc)?
#8 Опубликовано: 09.10.2024 18:47:10
Here I cirumvent the limitations of the translation using multiple intervals of integration. Example from the interactive handbook.
Worksheet36.sm (40 КиБ) скачан 113 раз(а).
Новые сообщения
Нет новых сообщений
