Type of Graphs - Linear - Linear, Linear-Log, Log-Log
Type of Graphs - Linear - Linear, Linear-Log, Log-Log - Сообщения
#1 Опубликовано: 17.01.2017 20:50:12
Basile
Basile
8 сообщений из 172 понравились пользователям.
Can we have graphs of data
Linear - Linear, [Yes]
Linear-Log, ?
Log-Log, ?
Thank you,
Basile
#2 Опубликовано: 18.01.2017 04:20:37
NDTM Amarasekera
NDTM Amarasekera
I also tried semi-log using X-Y Plot, but could not find a way.
However, it is possible using ZedGraph plugin.
Davide Carpi 18.01.2017 10:33:00, frapuano 18.02.2018 08:47:00
#3 Опубликовано: 18.01.2017 13:05:03
loglog and semilog plots can be created with Maxima Draw.
Insert> Maxima> Maxima Draw2D
Then you can specify graphics objects. There is partial support for the settings in the context menu. These settings also can be specified in the graphics command list.
An example with log plot can be found here
loglog.sm (17 КиБ) скачан 297 раз(а).
sergio 18.01.2017 15:34:00, Radovan Omorjan 18.01.2017 15:36:00, Davide Carpi 18.01.2017 19:51:00, frapuano 18.02.2018 08:46:00
#4 Опубликовано: 18.01.2017 19:37:32
Linear-Log, ?
Log-Log, ?
Thank you,
Basile
I don't catch "ndtma" plot, it looks to me a "qq plot".
This type of plot is on linear/linear. log scale is a
means to visualise globally large range of values.
You could probably manage your demand inspired from
the "logpts" attached.
Utilities logpts.sm (42 КиБ) скачан 200 раз(а).
