What is the matrix function to find the extrapolated value from a given 2-dimension table
What is the matrix function to find the extrapolated value from a given 2-dimension table - Сообщения
#1 Опубликовано: 21.04.2021 16:46:53
Tuan Nguyen
Tuan Nguyen
0 сообщений из 16 понравились пользователям.
Is there such matrix function to help me get the coefficient Cf based on ratio s/h and B/s from given table in matrix form?
#2 Опубликовано: 21.04.2021 17:38:34
You can either use linterp() or InterpBilinear().
They can also find an interpolated value between title numbers.
Please look at the Reference Book for further information.
#3 Опубликовано: 21.04.2021 18:05:55
Tuan Nguyen
Tuan Nguyen
Thank you. Found it here. https://en.smath.com/forum/yaf_postst17672_Interpolate-Matrix.aspx
Learn new things every day.
#4 Опубликовано: 21.04.2021 18:24:29
Spline(M,x,y) is universal.
Construct 1/1 from the given example, forget decoration <, >
Just for interpolation, you don't need the rotation system.
Spline Matrix Tutorial RECTANGULAR Surface Plot.sm (22 КиБ) скачан 70 раз(а).
Tuan Nguyen 21.04.2021 19:04:00
#5 Опубликовано: 21.04.2021 18:33:04
... nice example done for Smath Community visitor.
Construct rough data table, spline at will, plot is most delightful.
How do you manage ... Jean
SplineRectangularMatrix Isentropic Surface.sm (457 КиБ) скачан 51 раз(а).
#6 Опубликовано: 21.04.2021 19:13:21
Tuan Nguyen
Tuan Nguyen
Beautiful. I love the way you present all math problems in such a lovely form.
Even though it is a very rare case, when x and/or y values exceed the range in my posted table the function will return the value more or less than it should be because I think the table cap the values. I wanted to make changes to the Spline function to reflect this but my limited knowledge in programing and Smath prevents me from doing that. Any suggestions?
#7 Опубликовано: 22.04.2021 13:50:04
See you soon tomorrow ... Jean.
... here is, play with rotation.
Spline Matrix Tutorial RECTANGULAR Surface Plot Example.sm (23 КиБ) скачан 50 раз(а).
Tuan Nguyen 22.04.2021 14:42:00
#8 Опубликовано: 22.04.2021 14:47:20
Tuan Nguyen
Tuan Nguyen
Awesome. When x=70, y=0.5, I need it to be 1.75 per code because x>45 but the function gives me 1.83. How would I modify the code for Spline to achieve this.
#9 Опубликовано: 22.04.2021 15:37:25
Obviously the function uses linear extrapolation beyond the limits of the data array.
Without touching the function you can enforce constant extrapolation by repeating the first or last rows or columns of data.
surface.sm (18 КиБ) скачан 51 раз(а).
Tuan Nguyen 22.04.2021 18:37:00
#10 Опубликовано: 22.04.2021 16:46:35
... as simple as that, preserving last two cols linearity.
#11 Опубликовано: 22.04.2021 18:41:11
Tuan Nguyen
Tuan Nguyen
Me feeling dumb. Thanks, Jean and MKraska
