[SS-2311][MAXIMA] Why doesn't work in 0.98? - Сообщения
#1 Опубликовано: 05.04.2016 07:25:16
#2 Опубликовано: 05.04.2016 08:24:49
Василий Николаевич Храмушин 09.04.2016 00:49:00
#3 Опубликовано: 05.04.2016 12:07:16
WroteПожалуйста поправьте ошибку, появившуюся после версии 097-5890
Прикрепи .SM файл с ошибкой к сообщению... Видишь, у Михаила все работает и сложно разобраться что к чему (то есть в проге ли ошибка или в твоем документе)
#4 Опубликовано: 05.04.2016 12:23:32
#5 Опубликовано: 06.04.2016 00:58:56
In the new version of Smath Studio ( 0.98 5935 ) , the "diff" function does not work properly, and gives the following error : diff () function is not defined.
#6 Опубликовано: 06.04.2016 01:04:15
WroteIn the new version of Smath Studio ( 0.98 5935 ) , the "diff" function does not work properly, and gives the following error : diff () function is not defined.
Could you guys please check if a plugin causes that? Does disabling plugins solve the problem?
С уважением,
Михаил Каганский
#7 Опубликовано: 06.04.2016 01:29:08
#8 Опубликовано: 06.04.2016 01:43:59
The question isn't in if it worked before. The question is, if this is some plugin, then its maintainer should update it, because it apparently is broken. Bare SMath's diff works well (at least in some installations, e.g. mine, with English locale). So, could you check if you can fix the problem turning off some plugin, and if yes, then which plugin is that?
С уважением,
Михаил Каганский
#9 Опубликовано: 06.04.2016 01:59:26
Maxima diff takes scalar fuction. You are feeding a vector.
diff("1:expression", "2:expression") -
[built-in] or [Maxima] derivate(expr, var) derivates expr
with respect to var. diff((1+x+x^2+y),x) => 1+2*x
It could be the previous new version included a new derivative
operator, something like Mathcad .
#10 Опубликовано: 06.04.2016 02:16:34
WroteThis worked very well with the previous version of
Smath Studio with the same plugins that I have installed.
Try other style 'diff'
Forum Legendre Test.sm (8 КиБ) скачан 94 раз(а).
#11 Опубликовано: 06.04.2016 12:40:43
I confirm. I already wrote about it
http://en.smath.info/forum/yaf_postst7423_Jacobi-matrix-can-not-find-the-numerical-result.aspx
My animation programs do not work in Smath 0.98 5935 , as Smath 0.98 5935 does not recognize the coding of the Jacobi
matrix.
http://en.smath.info/forum/yaf_postst2307_Method-A-B--Draghilev-and-animation-spatial-mechanisms.aspx
http://en.smath.info/forum/yaf_postst2734_Animation-of-mechanisms-with-two-or-more-degrees-of-freedom.aspx
Davide Carpi 10.05.2016 06:48:00
#12 Опубликовано: 06.04.2016 12:49:09
#13 Опубликовано: 06.04.2016 13:01:12
mikekaganki : I disable all plugins, and the problem persists .
It seems to be a bug in the new version
#14 Опубликовано: 06.04.2016 13:03:46
#15 Опубликовано: 06.04.2016 13:04:08
WroteYour "Forum Legendre Test.sm", file does not work correctly in the current version of SMath Studio that I have installed.
Thanks "CBG" for reporting. In Smath 5346 it does not go further than order 5,
it might ... but next century ! I was wise to tabulate "wr" the wi & roots.
So you can experiment. I have it otherwise from Mathcad but Smath does not
directly extract the coefficients for polyroots. If you are interested, in
that stuff, please let me know and see how we can collaborate.
I you read my just posted message "Install Smath 5935"
can you why I shit in my pants
Cheers, Jean
#16 Опубликовано: 06.04.2016 13:40:40
Thanks "ndtma" for checking.
Does that mean the chiken is still live in the pot ?
#17 Опубликовано: 06.04.2016 13:50:51
I'm sure Smath 5935 is a working version in the creators machine.
But another story on users machine. Thus the need to proper intructions
how to uninstall previous, install new. Not so simple from Mathcad 11 that
made new 11 owners go crazy. A strict rigid procedure was not given.
#18 Опубликовано: 06.04.2016 13:51:27
Hi Jean,
Thanks.
The culprit is the Maxima plugin. We have to delete this plug in to get your program to run correctly.
If the plugin is disabled and then re-calculated, the program will run correct.
However, disabling is not effective, as the error will re-appear when the program is reloaded.
The error is reproduced below.
Thanks.
#19 Опубликовано: 06.04.2016 14:12:25
Andrey Ivashov 06.04.2016 14:16:00
#20 Опубликовано: 08.04.2016 11:42:48
SMath заново переустановил, с нуля, однако чуда не случилось. Очень печально. ОС - Windows-10/64 на AMD A8-4555 APU with Radeon
Dipole-3.sm (39 КиБ) скачан 39 раз(а).
Новые сообщения
Нет новых сообщений
