Hydraulic calculation of the pipeline
Hydraulic calculation of the pipeline - Сообщения
#1 Опубликовано: 06.11.2021 13:46:38
Tolik
Tolik
Hello.
I just started to study the program on my own.
And I don’t know how to build dependency graphs V(Q), Re(Q), lambda(Q) and delta p1 (Q) (see the file).
Сan you help with advice?
Thanks in advance.
Raschjot gidrolinii.sm (17 КиБ) скачан 56 раз(а).
#2 Опубликовано: 06.11.2021 15:38:53
Maybe Colebrook will help to complete your document.
Raschjot gidrolinii [incomplete].sm (18 КиБ) скачан 54 раз(а).
Inst_Colebrook Pipe Data.sm (71 КиБ) скачан 59 раз(а).
Tolik 06.11.2021 16:41:00
#3 Опубликовано: 06.11.2021 16:42:30
Tolik
Tolik
Thank you for the help
#4 Опубликовано: 06.11.2021 16:49:50
Here is a tip to your projects.
SMath vector/matrix/array indexes start from 1, not 0.
That will cause problems on your worksheets.
If you are rewriting a page from mathcad or similar, keep this in mind.
Tolik 07.11.2021 06:23:00
#5 Опубликовано: 07.11.2021 06:29:25
Tolik
Tolik
Thanks for the help.
I found another mistake.
Everything works now.
Now I'm trying to plot graphs...
Raschjot gidrolinii.sm (1 МиБ) скачан 50 раз(а).
#6 Опубликовано: 07.11.2021 08:16:26
Fridel Selitsky
Fridel Selitsky
Changed the code a little and built a variant of the graphs
Raschjot gidr.sm (40 КиБ) скачан 60 раз(а).
Tolik 07.11.2021 10:01:00
#7 Опубликовано: 07.11.2021 10:38:05
Tolik
Tolik
Your solution is very beautiful
#8 Опубликовано: 07.11.2021 10:39:02
I saved in my personal file.
Check Δp ... it looks bizarre.
Inst_Colebrook PipeLine [unk].sm (19 КиБ) скачан 57 раз(а).
Tolik 07.11.2021 11:21:00
#9 Опубликовано: 07.11.2021 11:26:11
Tolik
Tolik
Thank you, Jean. You're right
I understand.
Because Lambda is calculated using three different formulas.
Interpolation is also needed.
But overall the solution looks right.
Best regards, Tolik
#10 Опубликовано: 07.11.2021 12:25:28
Tolik
Tolik
Approximation in this case
#11 Опубликовано: 07.11.2021 14:25:11
I understand.
Best regards, Tolik
Nothing wrong to adapt third segment for a smooth junction,
or simply ignore for elongating 2nd segment.
Take care ... Jean.
Inst_Colebrook PipeLine [unk].sm (24 КиБ) скачан 58 раз(а).
Tolik 08.11.2021 18:22:00
#12 Опубликовано: 08.11.2021 08:52:26
I understand.
Best regards, Tolik
I think you should initialize λ1:=64
Δp interpolation is straightforward as given.
λ interpolation will surely need Thiele.
Please, let me know if you want λ interpolation.
Have a good day Kamarad ... Jean.
#13 Опубликовано: 08.11.2021 12:21:01
λinterpolation will surely need Thiele.
All your data sets have been converted to scalar functions.
Thiele is exceptional for Lambda.
By observation, Delta P needs better adjusting
segment 1 and segment 2 ... refine 2/3 junction.
All that done, it remains specific as demo, is it ?
Inst_Colebrook PipeLine [unk].sm (266 КиБ) скачан 46 раз(а).
#14 Опубликовано: 08.11.2021 14:08:11
... project refined for your comments.
Have a good visit ... Jean.
Inst_Colebrook PipeLine [unk].sm (267 КиБ) скачан 51 раз(а).
#15 Опубликовано: 08.11.2021 18:20:13
Tolik
Tolik
Sorry. I do not know the program well enough to properly evaluate your modifications and amendments.
You did a great job in my opinion.
In fact, the pressure will undergo two transitions.
The first transition: the destruction of the laminar flow and the appearance of the first large vortices.
The second transition: the core of the flow begins to touch the tops of the roughness of the pipe walls.
But I don't know exactly how they will affect the graph..
Yes, at this stage I needed to get a rough solution.
This is only the first section of the calculation of the system.
There are four of them.
Moreover, at the end, the pipeline has a branch. As a result, the solution is expected to be quite long.
Best regards, Tolik
#16 Опубликовано: 08.11.2021 19:49:49
Best regards, Tolik
Perpendicular branches create singular losses.
Better conserve this refreshed version.
Nice project ... Jean.
Inst_Colebrook PipeLine [unk].sm (88 КиБ) скачан 58 раз(а).
