Character conversion
Character conversion - Сообщения
#1 Опубликовано: 17.06.2018 16:36:37
Brian Runagle
Brian Runagle
13 сообщений из 27 понравились пользователям.
Hi
I'm looking for the equivalent to Excel ASCII functions
code("a" )=97 (space after " added to avoid a winking Smiley!)
char(97)="a"
and so on.
Does anyone know if they're hidden in a Plugin somewhere, or if there's an easy way to create them?
Many thanks
Brian
#2 Опубликовано: 17.06.2018 17:15:58
"a"
#3 Опубликовано: 17.06.2018 17:34:52
1230 сообщений из 2155 понравились пользователям.
There are some conversion functions in Maxima.
ascii.sm (4 КиБ) скачан 83 раз(а).
bdrunagle 17.06.2018 18:25:00
#4 Опубликовано: 17.06.2018 18:49:18
2276 сообщений из 3759 понравились пользователям.
Группа: Super Administrator
Hello.
Another example is available here: https://en.smath.info/forum/yaf_postsm47084_SMath-Studio-0-99-6617--12-February-2018.aspx#post47084
bdrunagle 18.06.2018 03:45:00
#5 Опубликовано: 18.06.2018 03:45:55
Brian Runagle
Brian Runagle
Thanks for your help gentlemen.
Brian
#6 Опубликовано: 18.06.2018 11:42:50
Hello.
There seems to be something special with the characters generated this way. They will be backconverted to code sequence if used in Maxima region, label region or table region.
Zeichenketten.sm (57 КиБ) скачан 77 раз(а).
#7 Опубликовано: 18.06.2018 12:25:29
Now I know why cint("A" ) does not work. It is a translation problem from SMath to Maxima, see SS-3543.
#8 Опубликовано: 18.06.2018 12:29:10
1418 сообщений из 2874 понравились пользователям.
They are special indeed, you can see it by exposing the plain text with copy/paste... The syntax is handled at code level by the math region (like a bbcode or a markdown text)
#9 Опубликовано: 18.06.2018 12:50:19
This is strange. I understand that the \xxxx\ markup can be convenient at input time or if the characters are generated from computed codes. But why need they to be stored this way? SMath can store and display the corresponding symbols directly.
I'd vote for an instant conversion and storage as unicode character, at least for those which actually can be displayed.
This would be closer to the paradigm "what you see is what is done".
frapuano 18.06.2018 13:46:00
#10 Опубликовано: 18.06.2018 14:06:19
Because many characters are taken by the math syntax... +-*/.,:;<>(){}@#! (and many more)... converting the code in character may cause trouble while reading back the code.
frapuano 18.06.2018 14:19:00
#11 Опубликовано: 19.06.2018 05:19:22
I see the point. But as far as string literals are concerned, a conversion could be done without harm (except for string markup character).
#12 Опубликовано: 19.06.2018 07:43:29
Since we have num2str() and str2num() I don't think it is a good idea neither when they are in a math string; better to have some functions like in maxima to do it explicitely. Apart this, the only other improvement that I might think is to allow \C\ where C is the special character instead of his code (not sure if might have side effects, though).
#13 Опубликовано: 19.06.2018 12:29:06
Indeed, a function to generate un-encoded/un-escaped pristine special symbols for use in strings would do the job.
Then I would recommend to not conceal the encoding/escaping of symbols in strings but rather just expose the raw version. Then nobody would expect to see the pretty-printed version in custom regions.
#14 Опубликовано: 19.06.2018 14:40:57
Not sure if this is what you mean, but we have GlobalProfile.ReplaceUnicodeChars(text) to decode term text.
