1 страниц (10 вхождений)
linterp help - Сообщения
#1 Опубликовано: 17.01.2024 10:19:48
I'm pretty sure it's possible and saw it somewhere here. How do I put this in a single matrix, along with the descriptors like "roof angle, "1", "2E",...etc. and use it for interpolation. Well I can get by using a single column matrix as a work around but I guess I want a more compact looking solution, if that makes sense.
#2 Опубликовано: 17.01.2024 16:00:11
Look for InterpBilinear() function.
You can find more info in Reference Book.
InterpBilinear.sm (8 КиБ) скачан 70 раз(а).
#3 Опубликовано: 17.01.2024 16:03:13
ohh didn't know about that. big thanks.
#4 Опубликовано: 17.01.2024 18:02:20
Surface plot is especially coded for your request.
Interpolate [Linterp, Spline2D] Copy.sm (201 КиБ) скачан 59 раз(а).
#5 Опубликовано: 17.01.2024 20:45:37
Using linterp() with a function is another way.
Function selects column according to input.
linterp_select.sm (8 КиБ) скачан 63 раз(а).
#6 Опубликовано: 18.01.2024 10:10:49
I'm quite satisfied with the InterpBilinear function. I'm exploring Jean's and overlord's additional suggestion but still it was already solved for me. Another question is that would that still work if I had to do interpolation in both the column values and row values such as in case below.
From what I understand, InterBilinear() seems incapable of doing what I aim to do. Do you have any suggestions?
#7 Опубликовано: 18.01.2024 18:37:38
#8 Опубликовано: 18.01.2024 19:10:51
WroteFrom what I understand, InterBilinear() seems incapable of doing what I aim to do. Do you have any suggestions ?
If, I understand your request,
ForLoop algo style will do ... last example page 10.
Interpolate [Linterp, Spline2D].sm (212 КиБ) скачан 56 раз(а).
#9 Опубликовано: 18.01.2024 20:25:30
#10 Опубликовано: 20.01.2024 04:15:39
WroteI want a more compact looking solution, if that makes sense.
Visit Samples for bidirectional interpolating Matrix.
Новые сообщения
Нет новых сообщений
