Variable not recognized when dividing
Variable not recognized when dividing - Сообщения
#1 Опубликовано: 18.05.2021 06:31:31
gntech
gntech
5 сообщений из 19 понравились пользователям.
If I make a division where a variable is the denominator sometimes the variable is not recognized. See below, in the last row the variable is not recognized.
I have discovered that the bug depends on that the variable must have a subscript and also how I enter the equal sign.
If I enter the equal sign while the marker is still positioned next to the denominator then everything is alright.
But if I press right arrow and then equal sign the variable is not recognized.
Andrey Ivashov 18.05.2021 09:23:00
#2 Опубликовано: 18.05.2021 11:41:31
gntech
gntech
Thanks for taking the time to answer. Are you referring to SMath Studio version 6179? I forgot to mention in my first post but I am using the recently released stable version 0.99.7808
The exact key sequence to reproduce the bug is as follows:
A,L:10(Enter)
1/A,Tab(RightArrow)=
The following also produces the bug:
A,L:10(Enter)
1/A,L(RightArrow)=
Please try those sequences
#3 Опубликовано: 18.05.2021 12:00:06
gntech
gntech
... for users of your latest SS version ?
No, I meant, to see if you can confirm/reproduce the bug on another system. Since you seem to say that you could not reproduce the bug on your system. Or have I understood something wrong?
SS 6179 Does NOT reproduce your bug.
Edit: Or do you mean that you have triaged the bug to have appeared after SS 6179 ?
#4 Опубликовано: 18.05.2021 12:12:24
Группа: Super Administrator
A,L:10(Enter)
A,L:10(Enter)
1/A,L(RightArrow)=
Thank you very much!
Issue is reproduced. Will fix it asap.
Best regards, Andrey Ivashov.
#5 Опубликовано: 18.05.2021 14:53:58
Thank you very much, this is most likely the cause we were looking for here.
#6 Опубликовано: 18.05.2021 17:13:59
gntech
gntech
Thanks Andrey and Davide, I am very happy to have been able to help you on this issue
I have done some more testing and found that the key elements to reproduce the bug is that the last variable entered has a subscript and that "RightArrow" is pressed before pressing equal sign.
So for example:
A.L:3
3*A.L(RightArrow)=
2^A.L(RightArrow)=
#7 Опубликовано: 18.05.2021 17:19:02
Issue is fixed. Will be included into the next release.
Thank you!
sergio 19.05.2021 04:45:00
