Data Exchange plugin - share data between SMath Studio and CSV/ODF/ODS/ODT/XeLaTeX files - Сообщения
I think he is looking for a general search & replace, both for math and text and able to acting on the whole worksheet.
I'm working on something, search works pretty fine with small limitations
I have problems with the export XeLaTeX.
First it is highlighted exception
Proceeding is inhibited the choice of options
Proceeding is nevertheless produced a tex file
You must still add the following line in the markup to fill in XeLaTeX
\newcommand{\defeq}{\coloneq} % SMath 'define equal' symbol
PS some addition function is not implemented, however, the qualitative result of the prints obtained is much higher than that of normal export pdf. I would hate a little if this project was abandoned
[albumimg]1437[/albumimg]
WroteHello Davide,
I see, seems something related to multithreading vs Forms. I have to ask Andrey, but I think that I have to remove the dialog from the save flow.
WrotePS some addition function is not implemented, however, the qualitative result of the prints obtained is much higher than that of normal export pdf. I would hate a little if this project was abandoned
The project is not abandoned, but you know, there are a lot of plugins and I have to find a little bit of time for each one. I'll implement the missing functions ASAP.
with regard to functions not implemented do not worry there is always the possibility to act manually (thank you for the tremendous efforts of multiple plugins). For the mistake the question is more annoying: Andrey hopefully give a solution.
- SS 0.98: fixed crash on save due to the Forms vs MTA;
- ODT, TEX files: added Command Prompt flags (see documentation in 1st post);
- ODT, TEX files: added more functions (vectorize, Floor, Ceil, at, cases, ternary booleans, absolute-definition's functions), fixed glitches in functions' names in ODT files, minor fixes & improvements;
- TEX files: all worksheet's metadata are now stored in the \doc***** variables;
the problem indicated in the post #141 has been resolved
I need this to be a formulas that can easy edit in MS Word lately.
Please, give straight link on plugin or help me to solve this promblem.
kursach SG.sm (376 КиБ) скачан 94 раз(а).
To download and install it, you need to go to menu Tools->Plugins, there make sure that "Plugins" is selected in the left pane, then click the "Local Storage" button over the plugins list, select "Online Gallery" and find the plugin there. Select it, and click "Install" at the bottom of the window.
If you want "ODF", but not "ODT", then there is no such thing as pure "ODF". There are a number of Open Document Formats available, among them: ODT for text documents, ODS for spreadsheets, ODP for presentations, ODG for drawings, etc. What do you need specifically? MS Word since 2007SP2 is able to open ODT, Excel understands ODS, ... so what do you need? I cannot tell if they will import formulas OK, but that's up to you to test.
If you may, please answer me in russian.
There is no plugin "DataExchange" or similar with "odf,odt" in discription.
I already have plugin who called "DataExchange", but he dont' do his own case in particular that announced there
WroteODF Formulas (to export variables and functions);
I want the formula looks like this
But after i saved my file in .odt ( ODF text doc.) wordpad told me that there is content who was incorrectly
displayed.When i tried to open file in Word (2007 version) it cant be open beacuse
Translation: "Cant open file Office Open XML because of errors in his content"
WroteHello.
Хорошо
ЦитатаThere is no plugin "DataExchange" or similar with "odf,odt" in discription.
Это потому, что ...
ЦитатаI already have plugin who called "DataExchange"
Если какой-то плагин уже установлен, он не отображается в диалоге, пока к нему не выйдет обновление (тогда он будет подсвечен).
Цитатаbut he dont' do his own case in particular that announced there
I want the formula looks like this ...
displayed.When i tried to open file in Word (2007 version) it cant be open beacuse ...
Это не плагин "не делает того, что заявлено", а хреново работает MS Office. То, что WordPad не может его прочитать - так он вообще мало что может. А вот 2007 версия офиса, в которой появилась впервые поддержка ODF, получила очень плохую репутацию за некорректную поддержку - Майкрософт тогда вообще обвинили, что они саботируют ODF такой поддержкой.
Вот файл, открытый MS Word 2013 и пересохранённый в docx: kursach SG.docx (112 КиБ) скачан 86 раз(а).
Thank for help!
Is the plugin not supposed to work in the latest beta?
WroteThe importData.ODS function does not work in SMath 0.98.6398 (error message: function not defined)
Fixed, thank you!
PLUGIN UPDATED
- Fixed open document format support under MONO;
- Fixed wrong numerical output;
WroteYou can use a loop or vectorize() over the round function
Utilities Matrix roundup_n.sm (24 КиБ) скачан 100 раз(а).
But nothing can beat LaTeX if it is the print quality.
Converted .sm to .tex with SMath Studio "Save As->TeX".
Used MiKTeX, altered tex file a little bit and compiled with XeLaTeX.
Just for fun.
tex.zip (97 КиБ) скачан 103 раз(а).
Новые сообщения
Нет новых сообщений
