Unexpected behavior
Unexpected behavior - Сообщения
#1 Опубликовано: 23.08.2018 03:06:44
Alvaro Diaz Falconi
Alvaro Diaz Falconi
997 сообщений из 1676 понравились пользователям.
Hi. I can not understand why the argument of the last function "disappears"
Thanks in advance
#2 Опубликовано: 23.08.2018 05:01:02
1418 сообщений из 2874 понравились пользователям.
The answer is in dec2bas(x,b).
In the third row there is xx-m)/b; arguent:something inside the function is a pass-by-reference operation from the function to the argument, hence the behavior (900 becomes 0).
If you don't want it, assign x to an internal variable and do all the definition operations on that variable (f.e. z:x -> zz-m)/b)
sergio 23.08.2018 13:04:00
#3 Опубликовано: 23.08.2018 12:22:11
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Tante grazie Davide! I did not know where else I could look for the error, because I thought I had reviewed everything.
Davide Carpi 23.08.2018 20:52:00
