How i can write this formula in Smath Studio?
How i can write this formula in Smath Studio? - How i can write this formula in Smath Studio? - Сообщения
#1 Опубликовано: 18.05.2018 10:05:41
yuriy1996
yuriy1996
0 сообщений из 11 понравились пользователям.
I have one formula where it is necessary to make a sum in a way that takes into account 5 coefficients of a polynomial. In the sum he is marked as ak and I need that instead of ak there was a1..a2..a3 ... a4 ... a5. Also, for each polynomial account, the power K automatically changes from the index of the polynomial 1..2..3..4..5. How to implement it in this program? Also, I have several layers of reinforcement in the equation that should also be instead of Asi to As1...As2...As3...Asn and Sigma_si to Sigma_s1...Sigma_s2...Sigma_s3...Sigma_sn . Sorry for bad English.
Arkush1.sm (11 КиБ) скачан 73 раз(а).
#2 Опубликовано: 18.05.2018 10:32:44
You made the following error: you used "a.k" instead of "a[k". This way you did not create vectors to use in the summation with the counter. You need to do to define and then use As and Sigmas.
yuriy1996 18.05.2018 11:16:00
#3 Опубликовано: 18.05.2018 10:38:06
yuriy1996
yuriy1996
I corrected a.k for a[k but how do I set 5 values for one variable a[k?
#4 Опубликовано: 18.05.2018 10:55:32
for example a[1:=2.5 a[2:=3.21 a[3:=-7.1
so "a" is a vector
in the sum a[k
yuriy1996 18.05.2018 11:15:00
#5 Опубликовано: 18.05.2018 11:13:48
yuriy1996
yuriy1996
Unable to determine the value of an element since the item with the specified index does not exist -error
#6 Опубликовано: 18.05.2018 11:16:25
yuriy1996
yuriy1996
Arkush1.sm (14 КиБ) скачан 67 раз(а).
#7 Опубликовано: 18.05.2018 11:46:35
CBG
CBG
77 сообщений из 312 понравились пользователям.
Solution
Arkush1_CBG.sm (15 КиБ) скачан 79 раз(а).
Carlos
yuriy1996 18.05.2018 11:49:00
#8 Опубликовано: 18.05.2018 12:29:55
... you may clean/recast a bit.
Arkush1_CBG.sm (13 КиБ) скачан 71 раз(а).
#9 Опубликовано: 18.05.2018 13:18:18
You have 11 sets of 'a'
Easy to tabulate, is it what you want ?
#10 Опубликовано: 18.05.2018 13:51:50
NDTM Amarasekera
NDTM Amarasekera
Pl look at this. Error may have occurred when entering the formula???? Difficult to trace.
Unable to select individual components of the erroneous formula.
Arkush1_ndtma.sm (16 КиБ) скачан 74 раз(а).
#11 Опубликовано: 18.05.2018 14:53:49
Arkush1_CBG [data].sm (136 КиБ) скачан 80 раз(а).
#12 Опубликовано: 18.05.2018 21:34:10
There it seems the formula is ill posed wrt [4.1].
It shows bfcd as something not defined but the originator
has defined b, and defined fcd ... b*fcd.
