Stable: SMath Studio 0.99.7808 (18 May 2021) - Сообщения
List of changes(between 0.99.7632 and 0.99.7808 versions)
Улучшения
- Experimental support of new Document mode implemented;
- Added ability to select Custom Region PlugIn which will be used in Document Mode;
- Scaling mode is saved between sessions now;
- The following auto scaling modes added: page width, content width, full page;
- gf (Gram-force) unit added;
- Picture Region automatically scale drag'n'droped image according to available page width;
- Preview in SMath Viewer menu item added to Tools menu;
- Added support for Regions with custom line breaks;
- Support for page breaks added for Container Regions;
- "Break on pages bounds" menu item added to Text Region (option turned on by default for new documents);
- Support to format content fragments added in Text Region (font size, font family, font weight; font style, text decoration, text color, background color, lines interval, paragraphs in Document mode);
- Added possibility to restore automatic line breaks mode in Text Region by doubleclick on resizer;
- Document mode: Support for ordered/unordered lists added;
- Automatic replacement context menu item added to TextRegion;
- Search in TextRegion significantly improved;
- Text Region: Show all characters context menu item added;
- Account menu item added to UI: allows to log in using smath.com credentials to unlock additional features;
- Full version of the SMath Viewer is available based on Account status now;
- Worksheet Author field automatically filled in with a name from Account for new Worksheets/Documents;
- Ctrl+Enter allowed in TextRegion inside Worksheet now - adds a paragraph to the text;
- Inserting lists allowed in TextRegion inside Worksheet now;
- Interface translation to Hindi added;
- Multiple improvements performed in Search functionality (better support in MathRegion; critical issues fixed; better support for search in Descriptions and Area/Separator; automatic scrolling in Document mode);
- Cursor movement corrected while the mouse pointer is between the pages in Worksheet mode;
- About dialog improved: links to author/developer projects provided;
- Automatic update of the plug-ins on program start after installation of the new SMath Studio version implemented;
- Search Panel extended with the following options: Case sensitive, Whole word only, Exclude disabled, Exclude invisible;
- Text Region improved to support pasting Images/Regions from clipboard;
- Added ability to enable/disable compression of the Viewer output assemblies (may help to reduce false positive detection by AV);
- Detailed description added in the Account dialog.
Исправления
- Better support for broken Worksheet files implemented;
- Hidden exceptions fixed in SMath Viewer applications;
- Rendering of text improved (the same content looks more similar on screen and on print out);
- Multi-threading issues fixed in MathRegion and TextRegion;
- Disable/enable evaluation for Area Region when auto-evaluation disabled fixed;
- Critical error happened sometimes when using Del keyboard button in Math Region fixed;
- Issue related to pasting into Regions which contains description fixed;
- Printing when grid rendering enabled fixed;
- Critical issue rarely happens on file with specific Region types opening fixed;
- Fixed critical errors happened sometimes on file open;
- Blinking tooltips on status bar items hovering fixed;
- Visible special XML symbols fixed in Text Region;
- Issues related to work with ordered/unordered lists fixed;
- Loading of Area Titles and Region Description fixed;
- Handling of incorrectly used BR tag in TextRegion fixed;
- Critical error sometimes happened in TextRegion near line break fixed;
- Better control of Field content implemented for TextRegion;
- TextRegion functionality improved (history vs Children Regions, stability, performance);
- Possibility to specify/change text restored in SMath Viewer;
- Better cursor handling in TextRegion;
- SS-4635: Symbol "\" is allowed as a special character in Math Region now (related errors fixed);
- SS-4625: Children Regions locations and translations status when switching program language fixed;
- SS-4621: Spacing improved while rendering int(2)/int(4) functions;
- Changes to fix encoded terms text related issues in Math Region and Plot Region (including representation in Viewer);
- SS-3566: Automatic scrolling to the focused description text corrected;
- SS-4601: Lost of options on copy/paste of MathRegions fixed;
- Crash on start in Linux fixed - Account menu removed from version for Linux;
- Critical issue happens sometimes on text pasting fixed in Text Region;
- Rendering Font Styles fixed on Linux;
- SS-4661: Displaying ellipsys for large matrices fixed for results when Optimization set to None;
- Saving of the Worksheet previously opened without all required plug-ins loaded will not loose a data anymore;
- SS-4650:Loading plug-ins from the Network location allowed now (this fixes issues happens sometimes after copying plug-ins between computers);
- Critical error happened sometimes on editing Document fixed;
- Performance issue experienced with Worksheets/Documents containing Header/Footer fixed;
- Cursor movement corrected while the mouse pointer is between the pages in Document mode;
- Scrolling to cursor improved in Worksheet mode;
- Several text encoding related issues in MathRegion fixed;
- Worksheet/Document autoscrolling enabled during work with selection inside a Region;
- Minor improvements performed for scrolling;
- Switching to Header/Footer by doubleclick fixed for the Worksheets contains Separator Region and background set;
- Text encoding related issue fixed in Plot Region;
- Critical issues happens on unexpected DoubleClickTime value provided by system fixed;
- Generating executables with SMath Viewer fixed;
- Incorrect cursor position fixed in Math Region for situations where multiplication operator automatically added before unit;
- Fixed content error happens during copy/paste inside TextRegion when working with content contains Regions;
- Behavior of save to Viewer dialog corrected.
Разное
- DEV: Line breaks is supported now for custom Regions (IRegionWithLineBreaks interface);
- DEV: Added possibility to extend SMath Studio with menu item in File, Edit, Tools or Help drop-down of main menu;
- Code cleanup;
- Refactoring;
- Smart auto replacement functionality implemented for Text Region in Document Mode (f.e. inserting --- finalized by Enter will be replaced with horizontal rule; filling in equation in text will be detected as well);
- Horizontal/vertical align toolbar buttons made hidden in Document mode;
- Children Regions rendering improved;
- Automatic replacement improved for MathRegions;
- TextRegion: Text selection rendering improved;
- Changing text formatting now affects on children Regions in the selected range;
- Document mode: Handling of complex formatting significantly improved;
- Selection logic improved in TextRegion;
- Handling of mouse click out of Region bounds improved in Document mode;
- Interface translations updated;
- MathRegion moved to a separate plug-in;
- AreaRegion moved to a separate plug-in;
- Support for non-standard DPI screens improved;
- Text Region stability significantly improved;
- Logic of line height setting improved for Text Region;
- Mouse cursor mode corrected for Text Region on mouse move with Ctrl/Shift button pressed;
- Displaying of the progress improved in Splash screen;
- Program startup speed improved.
Download
SMathStudioDesktop.0_99_7808.Mono.tar.gz (1 МиБ) скачан 3829 раз(а).
SMathStudioDesktop.0_99_7808.Setup.msi (2 МиБ) скачан 16913 раз(а).
- Desktop (Windows):
Framework: .NET Framework 2.0 or higher - Desktop (Linux):
- [ARA] Arabic / العربي
- [BEL] Belarusian / Беларуская
- [BUL] Bulgarian / Български
- [CAT] Catalan / Català
- [CHS] Chinese (Simplified) / 简体中文
- [CHT] Chinese (Traditional) / 簡體中文
- [CPP] Portuguese (Brazil) / Brazil (Português)
- [CZE] Czech / Čeština
- [DAN] Danish / Dansk
- [DUT] Dutch / Nederlands
- [ENG] English / English
- [FAS] Persian / فارسی
- [FIN] Finnish / Suomi
- [FRE] French / Français
- [GER] German / Deutsch
- [GRE] Greek / Ελληνικά
- [HEB] Hebrew / עברית
- [HUN] Hungarian / Magyar
- [IND] Indonesian / Bahasa Indonesia
- [ITA] Italian / Italiano
- [JPN] Japanese / 日本語
- [KOR] Korean / 한국어
- [LAV] Latvian / Latviešu
- [LTH] Lithuanian / Lietuvių
- [NOR] Norwegian / Norsk
- [POL] Polish / Polski
- [POR] Portuguese / Português
- [RON] Romanian / Română
- [RUS] Russian / Русский
- [SCC] Serbian (Latin) / Srpski
- [SCR] Croatian / Hrvatski
- [SLK] Slovak / Slovenčina
- [SPA] Spanish / Español
- [SRP] Serbian (Cyrillic) / Српски
- [SWE] Swedish / Svenska
- [TUR] Turkish / Türkçe
- [UKR] Ukrainian / Українська
SMathPrimer.pdf (Date: 11.11.2011. File size: 2.06MB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.Article.Eng.pdf (Date: 23.09.2009. File size: 828.96KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.IOFiles.Article.Eng.pdf (Date: 27.09.2009. File size: 453.24KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.NumericFunctions.Article.Eng.pdf (Date: 18.10.2009. File size: 622.45KB) - to open in Adobe Acrobat Reader
SMathStudio.0_85.Programming.Article.Eng.pdf (Date: 18.10.2009. File size: 411.74KB) - to open in Adobe Acrobat Reader
SMath Studio icons (
SMathStudio.Icons.zip (Date: 12.04.2010. Size: 63.74KB)
Hint regarding Account menu: if you want to change your displayed name please follow this link: https://en.smath.com/profile.aspx
WroteSMath Studio in the Cloud updated with Core ver. 0.99.7808.
Hint regarding Account menu: if you want to change your displayed name please follow this link: https://en.smath.com/profile.aspxiq test
Great tool for all engineers.
Новые сообщения
Нет новых сообщений
