Show the Orignal Units in Table Region
Show the Orignal Units in Table Region - Show the original units in the Table instead of the basic units of the International System - Сообщения
#1 Опубликовано: 21.03.2018 16:01:53
CBG
CBG
77 сообщений из 312 понравились пользователям.
Will it be possible?
Units_Table.sm (7 КиБ) скачан 113 раз(а).
Carlos
#2 Опубликовано: 21.03.2018 16:51:14
sets the header and units matrices
Davide Carpi 22.03.2018 08:17:00
#3 Опубликовано: 21.03.2018 20:22:36
CBG
CBG
Thanks Sergio:
You made me remember the solution that Martin Kraska gave me, but I can not put a header on it.
Do you have any suggestion?
Units_Table_r2.sm (15 КиБ) скачан 128 раз(а).
Carlos
#4 Опубликовано: 22.03.2018 06:35:19
I thought about this (string manipulation)
but num2strtransforms into fractions
#5 Опубликовано: 22.03.2018 13:36:09
I prefer the way we did in 1987, collecting piles of fluids information.
Units_Table Preference.sm (12 КиБ) скачан 131 раз(а).
#6 Опубликовано: 22.03.2018 13:44:41
1230 сообщений из 2155 понравились пользователям.
Use var2str() from CustomFunctions instead
sergio 22.03.2018 14:07:00, frapuano 22.03.2018 17:29:00
#7 Опубликовано: 22.03.2018 20:21:28
CBG
CBG
Thank you very much to everyone for your help,
I already managed to make the table as I required it.
Units_Table_r3.sm (9 КиБ) скачан 130 раз(а).
Carlos
frapuano 23.03.2018 04:14:00, Davide Carpi 23.03.2018 06:38:00
#8 Опубликовано: 22.03.2018 23:20:16
Thanks Carlos: gorgeous
#9 Опубликовано: 26.06.2018 18:32:55
wb.c
wb.c
26 сообщений из 156 понравились пользователям.
CBG,
Using the unit summary to convert units back to original units doesn't work for temperature conversions. What you are doing with the units summary assumes the conversion is a factored multiplier. It works great for everything except temperature (or any other unit doesn't scale by a factored multiplier).
#10 Опубликовано: 26.06.2018 21:28:04
Just define those units.
#11 Опубликовано: 26.06.2018 21:49:54
wb.c
wb.c
Jean Giraud,
Maybe try something other than 20 deg?...
Version: 0.99(build: 6671)
#12 Опубликовано: 26.06.2018 23:59:58
You are quite right and there are two things here
1. As it looks, the °C can't be made user.
The unit system is grounded on 'K', bloody pest to me.
2. The other thing is the Shadow in context, a real bug.
It worked fine from Carlos original [by what coincidence ?]
Not changing the context, context reproduces. Changing context
and the all thing °C gets freaked. I observed that many times
in Smath. In fact, very problematic.
Thanks for this wise observation.
Table Region Carlos.sm (10 КиБ) скачан 104 раз(а).
