1 страниц (7 вхождений)
import file ? - Сообщения
#1 Опубликовано: 17.06.2021 12:16:00
is it possible to import a file in txt to the smath and organize it by columns and rows???
#2 Опубликовано: 17.06.2021 13:49:55
#3 Опубликовано: 17.06.2021 15:39:09
#4 Опубликовано: 17.06.2021 15:49:26
If you could provide your file, it would be easier to check and input correct delimiters.
If you don't want to, just put a couple of lines. It can help to determine the function values.
#5 Опубликовано: 17.06.2021 16:18:48
#6 Опубликовано: 17.06.2021 16:27:20
Wrotethis it is the file, thanks for your help
ppp.txt (168 КиБ) скачан 92 раз(а).
You should write "ppp.txt" where you indicate your file.
You also just have to delete the first line from your data file.
It creates conflict between your function and data.
Data it provides don't match pattern of function.
So in result data can't be read.
Check below.
PS: martin is also right about getting partial data down below.
Новые сообщения
Нет новых сообщений
