Empty stack with maple
Empty stack with maple - Empty stack with maple - Сообщения
#1 Опубликовано: 04.07.2021 01:24:23
Bruno Choquepata
Bruno Choquepata
Hi everyone
I have to try to solve this equation with maple and solve but I only get the result "Empty stack", Someone knows solve it?
Moment_Curvature relationship.sm (940 КиБ) скачан 70 раз(а).
#2 Опубликовано: 04.07.2021 01:41:23
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. It seems that you put kd( ... ) instead kd*( ... ) in the maple solver.
#3 Опубликовано: 04.07.2021 02:17:03
Bruno Choquepata
Bruno Choquepata
Alvaro thanks for you answer but
"kd" is the only value unknown
#4 Опубликовано: 04.07.2021 02:24:47
Alvaro Diaz Falconi
Alvaro Diaz Falconi
In the first expression it is kd( ... ). In the second it is kd*( ... ). There the maple answer uses RootOf, I'm guess that because you have another issue in the expression. For instance A.s*Fy have units of Newtons, but the other part not.
Bruno Choquepata 04.07.2021 03:11:00
#5 Опубликовано: 04.07.2021 03:14:36
Bruno Choquepata
Bruno Choquepata
Thanks a lot Alvaro
#6 Опубликовано: 04.07.2021 09:29:55
Thanks a lot Alvaro
Alvaro is right.
Left side of equation is N (kg*m/s^2), right side is J (kg*m^2/s^2).
A dimension should be extra or missing in that equation.
Probably not correct solution but if you equate units;
#7 Опубликовано: 04.07.2021 12:33:54
1. RootOf expands easily [Example 1]
2. root is undocumented, most precious for dual solver [Example 2]
3. allvalues ... most precious in invlaplace [Example 3]
Maple RootOf Example.sm (38 КиБ) скачан 72 раз(а).
