1 страниц (8 вхождений)
Differentiation operator does not evaluate symbolically - Translate a differential operator from SMath to Maxima - Сообщения
#1 Опубликовано: 30.05.2020 21:46:04
Do you know why or what could be the problem for SMath not translating properly a dy/dx. I need to write these operators in Maxima to solve a differential equation...
Thanks in advance,
Differentiation.sm (9 КиБ) скачан 45 раз(а).
Thanks in advance,
#2 Опубликовано: 30.05.2020 22:23:02
I have found a workaround, with eval_string() from Maxima.
Differentiation.sm (13 КиБ) скачан 57 раз(а).
#3 Опубликовано: 30.05.2020 23:55:54
WroteHello,
Hola tocayo. Is this the problem?: always it is diff(y,x)=0, but diff(y(x),x) remains unevaluated and is the correct form to express the derivative of a function.
frapuano 31.05.2020 04:51:00
#4 Опубликовано: 31.05.2020 00:16:30
#5 Опубликовано: 31.05.2020 08:12:03
You are mixing two CAS that will not pass QA [Quality Assurance].
My understanding is that what was usable from Maxima is native in Smath.
Smath native derivative operator works from book library.
sin(x), ln(x), exp(x) ... OK
Gamma(x), erf(x) ... zap. We have them otherwise.
Differentiation.sm (17 КиБ) скачан 72 раз(а).
#6 Опубликовано: 31.05.2020 10:29:55
Thank you Jean, I am trying to test some symbolic solutions of differential equations just for a course video where I show some of the capabilities that are not present in Mathcad (Prime).
#7 Опубликовано: 31.05.2020 12:42:32
WroteThank you Jean, I am trying to test some symbolic solutions of differential equations just for a course video where I show some of the capabilities that are not present in Mathcad (Prime).
Very few DE have symbolic solutions, unless from Handbooks.
Few of them are available in Smath ... will be back on that.
#8 Опубликовано: 31.05.2020 18:46:56
WroteI am trying to test some symbolic solutions of differential equations just for a course video where I show some of the capabilities that are not present in Mathcad (Prime).
If Mathcad Prime does not solve those attached ... Oh !
ODE Symbolic 4_Flies.sm (130 КиБ) скачан 60 раз(а).
ODE Symbolic Bernoulli.sm (11 КиБ) скачан 58 раз(а).
ODE_Laplace 1rst [Type 2].sm (22 КиБ) скачан 59 раз(а).
ODE Symbolic Verhulst [Logistic].sm (25 КиБ) скачан 53 раз(а).
ODE Symbolic Lambert.sm (21 КиБ) скачан 43 раз(а).
ODE_Laplace 1rst [Type 1].sm (24 КиБ) скачан 57 раз(а).
ODE_Laplace 2nd [Type 3].sm (34 КиБ) скачан 50 раз(а).
ODE Symbolic Eiffel.sm (21 КиБ) скачан 55 раз(а).
Новые сообщения
Нет новых сообщений
