1 страниц (7 вхождений)
pH Solution - pH Solution - Сообщения
#1 Опубликовано: 10.07.2018 19:33:33
#2 Опубликовано: 10.07.2018 23:36:55
WroteWorks fine.
... refreshed, optimized calculation timing
Added the buffered plot to be splined for + values.
Inst_pH Solution.sm (44 КиБ) скачан 89 раз(а)....refreshed/augmented
#3 Опубликовано: 11.07.2018 04:42:18
325 сообщений из 2052 понравились и 1 не понравились пользователям.
Hello Jean,
For me, the first plot is working
but the second is not - cases() is complaining.
I could see that sigma2 went nuts (do not know why) and put eval() in front of it
I do not have the explanation of this - might be a bug.
#4 Опубликовано: 11.07.2018 08:09:43
WroteI do not have the explanation of this - might be a bug.
1. Can't understand the error cases(,) [6671]
2. Make unit K was first problem , done well.
3. Doctoring for the spikes works and accelerates calculation timing.
Inst_pH Solution Copy.sm (46 КиБ) скачан 74 раз(а).
#5 Опубликовано: 11.07.2018 19:21:14
Can you explain sheet. I was looking at creating a Langelier Saturation Index (LSI) for quick analysis and this appears to be going in that direction
#6 Опубликовано: 11.07.2018 23:16:55
WroteCan you explain sheet.I was looking at creating a Langelier Saturation Index (LSI) for quick analysis and this appears to be going in that direction
The program is a dual iterative solver.
Give some more about Langelier saturation index.
#7 Опубликовано: 11.07.2018 23:49:28
WroteI was looking at creating a Langelier Saturation Index (LSI)
Langelier saturation index [LI] has nothing to do wrt unbuffered.
As it looks, there are lot of those things already tabulated.
Wait and see if you can come up with some interesting stuff.
Новые сообщения
Нет новых сообщений
