1 страниц (4 вхождений)
substitute variables - how to substitute variables into the function - Сообщения
#1 Опубликовано: 28.06.2022 15:53:21
Is there some way how to substitute variables into the function? For example I define two variables:
a=1m
b=2m
and then I define function A=a·b=2m^2
But I need something like this A=a·b=1·2=2m^2
Is it possible?
a=1m
b=2m
Is it possible?
#2 Опубликовано: 28.06.2022 17:05:29
Greetings!
This is possible, but there is some work involved to make it happen. After you define your variables a and b, do the following:
STEP 1) Insert a text region (i.e., Keypress the double quotes [ " ]); this used to keep math/text on the same line.
STEP 2) Type your equation 「A:a*b=#」, the text 「 = 」, and the equation 「A=#」 into your text region.
STEP 3) Right-click your 1st Equation, on your context menu you will see [Optimization]; change this option to [None]
STEP 4) Right-Click your 2nd Equation, on your context menu: uncheck the [Display input data] option.
NOTES: With units, it will simplify 「1*m」 to 「m」; so this isn't a perfect solution by any means.
Example:
Here is a file with an example: SMath - substituting variables into same equation.sm (46 КиБ) скачан 103 раз(а).
Hope this helps!
Kenny Lemens, P.E.
Reference post #8 on forum: https://en.smath.com/forum/yaf_postst17400_Edit-workflow-for-text-regions-with-embedded-math.aspx
Example:
Hope this helps!
Kenny Lemens, P.E.
#3 Опубликовано: 28.06.2022 22:43:35
Hi. It would be great to have a new equals sign, such as ≡ , that shows the substitution of an expression for its values, but without the rounding problems that this proposed solution has, and showing the final result in Pascals, perhaps.
show.sm (14 КиБ) скачан 136 раз(а).
show.pdf (56 КиБ) скачан 116 раз(а).
#4 Опубликовано: 29.06.2022 11:15:54
When it comes to expand/explicit maths formulas,
it soon turns a monkey business, that hits the wall.
Inspect the 14 same representations, and few more.
Enjoy ... Jean.
Maths 0 Formula Representations QUICK.sm (33 КиБ) скачан 161 раз(а).
Enjoy ... Jean.
Новые сообщения
Нет новых сообщений
