1 страниц (6 вхождений)
Standard templates? - Is it possible to create (and re-use) a template in smath? - Сообщения
#1 Опубликовано: 03.08.2020 13:51:52
Hi everyone, I’ve been using smath for about a year now (since mathcad became completely rubbish!) and use it for standard engineering calcs (mechanical and structural mainly).
I’m freelance so tend to perform calcs for many clients and have not yet found a way to create a standard calculation sheet template.
For example, whenever I start a new project I’d like a header or something on the front page to display my company name and a few other fields for title, project number, that sort of thing. Possibly even have a margin down one side for referencing standards or notes. Something like the sci calc sheets that are online would be great!
Does anyone know of a way to do this or is there a plug-in somewhere?
Any advice would be much appreciated.
Thanks!
Richard
Thanks!
Richard
#2 Опубликовано: 03.08.2020 14:19:01
you can use:
Insert -> Header and Footer
Insert -> Field
Also you can see this post by Alvaro (Razonar)
https://en.smath.com/forum/yaf_postst13853_Automatic-numbering-sections-book.aspx
Insert -> Field
#3 Опубликовано: 03.08.2020 14:29:06
Few ways of presenting professional works. Any use ?
Template.sm (15 КиБ) скачан 379 раз(а).
Template Background Multiple.sm (14 КиБ) скачан 255 раз(а).
Template Cartouche.sm (19 КиБ) скачан 185 раз(а).
Template Background Construct.sm (47 КиБ) скачан 232 раз(а).
Template Cartouche Venturi.sm (21 КиБ) скачан 146 раз(а).
Template Else Source.sm (3 КиБ) скачан 159 раз(а).
Template Cartouche CREATE.sm (53 КиБ) скачан 139 раз(а).
Template Cartouche Saved.sm (4 КиБ) скачан 129 раз(а).
Template Guy.sm (2 КиБ) скачан 171 раз(а).
Template Cartouche Example.sm (34 КиБ) скачан 156 раз(а).
Template YellowCorn.sm (3 КиБ) скачан 156 раз(а).
Template Cartouche Geoff.sm (31 КиБ) скачан 143 раз(а).
Template Cartouche Otherwise.sm (74 КиБ) скачан 161 раз(а).
#4 Опубликовано: 02.09.2020 09:48:17
Hi, apologies for the delayed response! The templates linked below are great - thank you for providing these.
I've looked at a few and haven't quite found what I need yet but I'll work on it. Once I have something I'll post it here so everyone else can use it (if they want to!)
Thanks again,
Richard
Thanks again,
Richard
#5 Опубликовано: 02.09.2020 13:15:51
WroteI've looked at a few and haven't quite found what I need yet
Visit them all for the next month !
Foot note standard/references best go in collapsed above document.
#6 Опубликовано: 05.01.2022 15:08:29
Create an empty file with your template settings and set it as readonly, when you try to save Smath will ask you a new name.
Новые сообщения
Нет новых сообщений
