Transferring three-dimensional image on a two-dimensional graph
Transferring three-dimensional image on a two-dimensional graph - Ber7 - Сообщения
#1 Опубликовано: 08.12.2013 11:51:06
Fridel Selitsky
Fridel Selitsky
This method was suggested by the author of the "Method of Draghilev" prof. Alexei Ivanov.
1.st through the matrix of three columns (x, y, z) to construct
3d graph and select the desired Rakurs;
2.Using linear coordinate transformations turn
all points of the matrix at an angle (angles) corresponding
Rakurs and obtain a new matrix;
3. Out of three columns of the new matrix choose two and
substitute them in 2d graph;
Animation shows two first surface constructed A.Ivashev second
V.Mezentsev (Bottom). The animation is done on a flat graph.
ButKlejn.smz (4 КиБ) скачан 175 раз(а).
Davide Carpi 08.12.2013 13:36:00
#2 Опубликовано: 28.12.2013 15:47:32
Fridel Selitsky
Fridel Selitsky
Updated.Fixed mistake in the first matrix coordinate transformation
Davide Carpi 31.01.2014 06:17:00
#3 Опубликовано: 16.01.2014 16:19:01
Fridel Selitsky
Fridel Selitsky
Animation spatial mechanisms
To calculate the position of the mechanism will use
techniques developed A.B.Ivanov.His work on 3d
animation mechanisms made ​​in Mapl, publishes A.B.Ivanov
online
http://forum.exponenta.ru/viewtopic.php?t=12842
Of the examples from this site I suffered in a programming environment SMath Studio
1. Sarrus linkage 1
#4 Опубликовано: 30.01.2014 16:14:59
Fridel Selitsky
Fridel Selitsky
TorSphere.smz (5 КиБ) скачан 168 раз(а).
Davide Carpi 31.01.2014 06:16:00
#5 Опубликовано: 05.11.2014 13:35:17
Fridel Selitsky
Fridel Selitsky
Rotation around the coordinate axes
ButKlejn.smz (6 КиБ) скачан 137 раз(а).
Davide Carpi 05.11.2014 14:10:00
#6 Опубликовано: 02.02.2015 11:03:15
Fridel Selitsky
Fridel Selitsky
1.Torsion and bending Plate
2.Torsion and bending cylindrical panel
Using nonlinear coordinate transformations
Plate.smz (6 КиБ) скачан 160 раз(а).
Andrey Ivashov 26.02.2016 09:19:00, Davide Carpi 02.02.2015 20:47:00, IVR 05.02.2015 15:07:00, ioan92 26.02.2016 07:12:00
#7 Опубликовано: 26.02.2016 06:57:04
Fridel Selitsky
Fridel Selitsky
Rotation About an Arbitrary Axis in Space
The algorithm is taken from the book. F. Rogers and J. A. Adams. Mathematical
Elements for Computer Graphics,second edition. McGraw-Hill Publishing Company,
1990,pages 121-127
Rotation2.smz (9 КиБ) скачан 126 раз(а).
Davide Carpi 26.02.2016 08:25:00, Andrey Ivashov 26.02.2016 09:19:00, ioan92 26.02.2016 10:57:00
#8 Опубликовано: 28.02.2016 18:17:42
Rotation2.smz ,,,, does not work Smath 5346
egamma: not defined [does not evaluate]
ex, ey, ez don't evaluate ,,,
Smath 5346 does not recognise Rotatio2 coding.
Thanks for the other ones.
#9 Опубликовано: 28.02.2016 21:30:29
Fridel Selitsky
Fridel Selitsky
For SMath 5890 file works fine. For SMath 5346 file can not verify.
#10 Опубликовано: 15.11.2016 16:29:15
Fridel Selitsky
Fridel Selitsky
Building the surface deflection a Circular Plate for periodically applied load (Smath 0.98.5935)
Timoshenko.sm (389 КиБ) скачан 156 раз(а).
Davide Carpi 15.11.2016 19:34:00
#11 Опубликовано: 16.11.2016 00:10:08
Thanks: very nice. That's how you can tell the age of the lady !
#12 Опубликовано: 23.02.2017 06:07:26
Fridel Selitsky
Fridel Selitsky
Tension,torsion and bending beams
Beams.smz (15 КиБ) скачан 125 раз(а).
Davide Carpi 23.02.2017 21:15:00
#13 Опубликовано: 19.04.2017 04:46:02
Fridel Selitsky
Fridel Selitsky
Dome of Viviani Windows
The dome is made out of a variable number of Viviani curves generated by the intersection of the
hemisphere and the moving cylinder.A real-life application of this can be seen at the Osaka Maritime Museum
https://en.wikipedia.org/wiki/Osaka_Maritime_Museum
V4.sm (23 КиБ) скачан 106 раз(а).
frapuano 19.04.2017 09:15:00, NDTM Amarasekera 19.04.2017 12:14:00, Davide Carpi 23.04.2017 19:33:00
#14 Опубликовано: 23.04.2017 06:24:49
Fridel Selitsky
Fridel Selitsky
Gateshead Millennium Bridge
http://en.wikipedia.org/wiki/Gateshead_Millennium_Bridge
The arch and the bridge deck can be rotated together around large bearings, lifting the bridge deck to let small ships and boats pass underneath. This is the essential idea behind the Gateshead Millennium Bridge, a pedestrian and cyclist tilt bridge. It spans the River Tyne in England between Gateshead on the south bank and Newcastle upon Tyne on the north bank.
Most.sm (34 КиБ) скачан 104 раз(а).
#15 Опубликовано: 26.04.2017 10:00:02
Fridel Selitsky
Fridel Selitsky
Continuation. The principle of operation of the bridge
Most.sm (34 КиБ) скачан 100 раз(а).
NDTM Amarasekera 26.04.2017 11:37:00, Arie 26.04.2017 11:13:00, Davide Carpi 26.04.2017 19:14:00, frapuano 27.04.2017 01:28:00
#16 Опубликовано: 05.06.2017 08:04:06
Fridel Selitsky
Fridel Selitsky
Beam of rectangular section. Very simple code.
Section.sm (17 КиБ) скачан 129 раз(а).
NDTM Amarasekera 05.06.2017 22:51:00, Davide Carpi 10.10.2017 11:52:00, Arie 05.06.2017 15:54:00
#17 Опубликовано: 05.06.2017 14:09:00
Thanks Ber7,
I love those things that move, but they dilute my "winter chicken brain" !!!
You may want to roll the torus. Very nice in Mathcad, unfortunately, can't
attach the animation because XP Pro. does not support any of the Mathcad "Codecs".
Torus.sm (155 КиБ) скачан 89 раз(а).
#18 Опубликовано: 08.10.2017 16:39:32
Fridel Selitsky
Fridel Selitsky
Rotation around an arbitrary axis defined by two points.Continuation
https://en.smath.info/forum/yaf_postsm30728_Transferring-three-dimensional-image-on-a-two-dimensional--flat--graph-by-prof--A-B-Ivanov.aspx#post30728
Rotation3.sm (35 КиБ) скачан 97 раз(а).
#19 Опубликовано: 09.04.2018 15:42:55
Fridel Selitsky
Fridel Selitsky
Updated
Rotation4.sm (27 КиБ) скачан 87 раз(а).
Davide Carpi 10.04.2018 04:11:00
#20 Опубликовано: 05.06.2018 12:31:28
Fridel Selitsky
Fridel Selitsky
The spiral curved along a given 3d curve
Spiral1.sm (21 КиБ) скачан 90 раз(а).
Spiral4.sm (20 КиБ) скачан 88 раз(а).
Spiral5.sm (19 КиБ) скачан 82 раз(а).
Davide Carpi 05.05.2020 15:56:00
