bug with function with programming
bug with function with programming - calling function with a for loop loops forever - Сообщения
#1 Опубликовано: 14.10.2019 22:03:17
jcuadra
jcuadra
0 сообщений из 12 понравились пользователям.
Firstly thank you for such a wonderful free alternative to MathCad 15.
Please see attached .sm file.
The comments describe the bug ...
Thanks in advance
test bug.sm (16 КиБ) скачан 79 раз(а).
#2 Опубликовано: 15.10.2019 04:54:29
Thanks in advance
Did not reproduce it...
Arie 15.10.2019 10:16:00, NDTM Amarasekera 15.10.2019 11:01:00
#3 Опубликовано: 15.10.2019 10:16:05
Arie
Arie
93 сообщений из 285 понравились пользователям.
I could not reproduce either..
#4 Опубликовано: 15.10.2019 10:59:18
NDTM Amarasekera
NDTM Amarasekera
Yes, did not reproduce.
#5 Опубликовано: 15.10.2019 13:02:21
jcuadra
jcuadra
Hmm,
I just re-tested on my home PC, freshly booted, same problem.
appVersion(3) = "0.99.7030" not .7219 <- Could this be the difference?
#6 Опубликовано: 15.10.2019 13:17:34
Arie
Arie
Hmm,
I can confirm this hangs on 7030. I was running 7219 before and did not have an issue. My guess is this should be fixed in next stable release and already seems to be fixed in Beta releases. The question is whether or not the "fix" is intentional or not.
#7 Опубликовано: 15.10.2019 13:22:49
jcuadra
jcuadra
OK thanks.
I will install 7219.
Hopefully my Maxima plugin continues to work.
#8 Опубликовано: 15.10.2019 17:43:18
IMHO, not the best option yet.
Who can guess what the angle for loop should be doing ?
There are no maths associated with !
#9 Опубликовано: 15.10.2019 18:05:01
test bug Red.sm (20 КиБ) скачан 55 раз(а).
#10 Опубликовано: 15.10.2019 20:26:19
jcuadra
jcuadra
angle was originally used as such, but I modified it as a troubleshooting step, with no change to the bug's behavior
loss := loss + I2ttot(sin(angle*deg)*Ipk)
#11 Опубликовано: 15.10.2019 20:42:45
jcuadra
jcuadra
OK thanks.
It works properly on .7219.
But Maxima doesn't work.
#12 Опубликовано: 16.10.2019 14:09:24
Arie
Arie
What error do you get? Maxima works fine on my end. May need to update the plugin.
#13 Опубликовано: 16.10.2019 16:26:24
jcuadra
jcuadra
^ Doesn't installing Maxima require running Update16.sm which will then upgrade it to .7030?
EDIT: I was able to get Maxima running with .7219.
#14 Опубликовано: 16.10.2019 18:34:02
No matter SS version, by far not a Mathcad clone.
Show some Mathcad snippets ... would help doctor the patient.
What from Maxima ? Plot, Solve ...
#15 Опубликовано: 17.10.2019 09:30:53
Arie
Arie
Not sure? Maybe Martin can answer. I already had maxima setup on a previous version. I simply updated to 7219 and Maxima came along for the ride.
#16 Опубликовано: 17.10.2019 10:14:05
jcuadra
jcuadra
I was able to install Maxima with .7219, thank you.
