Polynomials with complex coefficients
Polynomials with complex coefficients - Сообщения
#1 Опубликовано: 18.11.2023 08:47:14
Oichi
Oichi
3 сообщений из 35 понравились пользователям.
Hello, I want to solve a quartic polynomial with complex coefficients.. I tried "polyroots" function but it gives an error "cannot calculate",, Is there a plugin or a function that can solve a polynomial with complex coefficients in SMath? Thanks in advance
#2 Опубликовано: 18.11.2023 19:02:58
Oscar Campo
Oscar Campo
124 сообщений из 298 понравились пользователям.
Here an example solved by using Maxima plugin:
best,
Oscar
#3 Опубликовано: 18.11.2023 19:06:17
Oichi
Oichi
best,
Oscar
How to put these answers of Maxima plugin inside a vector?
#4 Опубликовано: 18.11.2023 20:03:43
If you have the complex quartic complex vector,
the way to plot is via Lagrange Iterated Product.
From there, your quartic is now a function in native Smath.
You can find roots and more solving demands.
#5 Опубликовано: 18.11.2023 20:18:30
You can use maple() too.
Maple has a fsolve() function.
Which uses floating-point arithmetic.
ioan92 18.11.2023 23:28:00, Oichi 18.11.2023 21:23:00, Oscar Campo 18.11.2023 20:21:00
#6 Опубликовано: 18.11.2023 20:25:02
Oscar Campo
Oscar Campo
A little trikiest
ioan92 18.11.2023 21:05:00, Oichi 18.11.2023 21:23:00
#7 Опубликовано: 18.11.2023 21:23:58
Oichi
Oichi
Okayy,,,The trick using num2str is so cool..
And thanks overlord, I didnt know about this maple one
Oscar Campo 18.11.2023 21:30:00
#8 Опубликовано: 19.11.2023 02:42:44
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. Another way.
zroots.sm (19 КиБ) скачан 54 раз(а).
Oscar Campo 19.11.2023 03:45:00, ioan92 19.11.2023 03:49:00
