Split Areas(Polygons convex and concave) by lines
Split Areas(Polygons convex and concave) by lines - Momentum curvature by fibers method - Сообщения
#1 Опубликовано: 29.07.2022 13:13:09
Jesus
Jesus
Hi everyone ,I'm doing a momentum curvature usign Popovic's Method and found a big problem beacuse to divide a polygon(convex and concave) into small fiber like this image but with more lines:
General Polygon
it's not so easy to do an algorithm. I did a smath file when the polygon it's rectangular but for more general case my smath code doesn't work, I'd like know an algorithm, code or function if it's posible in smath or other language to develop.
Jesus.
Verificacion_de_fluencia_en_acero_fiber_method_degradation_forum.pdf (550 КиБ) скачан 74 раз(а).
#2 Опубликовано: 29.07.2022 16:45:52
If I understand ...
Your polygon has 9 vertices, we can try a circular spline.
That will add as many points between vertices, is it ?
From there: Area, Perimeter, Center of Gravity.
Give the vertices... Jean.
#3 Опубликовано: 29.07.2022 18:10:04
Jesus
Jesus
Hi Jean, exactly I need to known the area, center of gravity and perimeter of the division but the polygon doesn't need to have 9 vertices, this is an example in this case. In general ,I'd like to calculate for n vertices polygon(convex or concave),let me give an example in smath for regular polygon.
polygon_2.sm (36 КиБ) скачан 51 раз(а).
Jesus.
#4 Опубликовано: 30.07.2022 15:49:15
Jesus
Jesus
Hi Jean, it was a good solution and you give some ideas to do a code but I'd like to do for more lines and I'd like to optimize the code or algorithm. I did a code in smath maybe need to optimize some parts and get some interesting results, i hope you take a look because a I'd like to aply to convex and no convex polygon, I think it's so hard but I'd like to know the algorithm or code that other programs use. My code doesn't work for some slopes though
Page5 Polygon Copy.sm (116 КиБ) скачан 54 раз(а).
Jesus.
#5 Опубликовано: 31.07.2022 07:45:01
General Polygon
Jesus.
This might be an application for the GPC wrapper plugin by Davide.
gpc1.sm (12 КиБ) скачан 61 раз(а).
#6 Опубликовано: 31.07.2022 12:37:52
Jesus
Jesus
Thank you so much, mkraska and Jean, I'll take a look this package (GPC wrapper).
Jesús.
#7 Опубликовано: 31.07.2022 16:06:27
Jesus
Jesus
Ok Jean, I hope You'll find an algorithm to solve that problem.
Jesus
#8 Опубликовано: 01.08.2022 14:09:35
Laurent Fournier
Laurent Fournier
9 сообщений из 66 понравились пользователям.
very exciting project!
#9 Опубликовано: 01.08.2022 14:23:17
Jesus
Jesus
Hi Jean it's an excellent solution, thank you so much , I did a code with GPC plugin and I could get this results.
polygon_irregular_fiber_borrador1.sm (34 КиБ) скачан 63 раз(а).
polygon_regular_fiber_borrador1.sm (35 КиБ) скачан 62 раз(а).
Jesus
#10 Опубликовано: 01.08.2022 15:19:08
... algo style to collapse in utilities.
#11 Опубликовано: 01.08.2022 19:06:15
General hatching procedure for arbitrary contours
gpc2.sm (42 КиБ) скачан 60 раз(а).
#12 Опубликовано: 02.08.2022 00:05:56
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. In the attached, a function for see if a point is inside or outside a polygon, and a code for double integrals using Gauss-Legendre coefficients.
InPoly.pdf (97 КиБ) скачан 61 раз(а).
InPoly.sm (43 КиБ) скачан 70 раз(а).
sergio 02.08.2022 11:10:00
#13 Опубликовано: 02.08.2022 02:44:17
Laurent Fournier
Laurent Fournier
Wow!
Will we be able to calculate the static moment and the moment of inertia of any section with these tools?
#14 Опубликовано: 02.08.2022 06:41:33
gpc3.sm (135 КиБ) скачан 92 раз(а).
#15 Опубликовано: 02.08.2022 09:21:54
Laurent Fournier
Laurent Fournier
That's superb!
Thanks a lot!
Has anyone worked on polyhedra, convex hulls and polar polyhedra?
#16 Опубликовано: 02.08.2022 11:16:59
... refreshed for convenience.
Maths Polygon Create.sm (99 КиБ) скачан 63 раз(а).
#17 Опубликовано: 02.08.2022 12:35:53
I may have something on convex hull
Polyhedra, we have C_60 extracted from the adjacency matrix.
#18 Опубликовано: 02.08.2022 13:41:40
Laurent Fournier
Laurent Fournier
anything on the adjacency matrix I am super interested!
Handling the adjacency matrix is the only difficulty in fact. Polarity of points-planes is easy.
#19 Опубликовано: 02.08.2022 20:47:43
1. In the attached Buckyball, adjacency matrix is from Mathsoft,
Mathsoft borrowed fro Matlab.
2. I have the Mathcad convex hull ORIGIN 0
RemToDo ORIGIN 1 for Smath coding.
Buckyball Adjacency.sm (16 КиБ) скачан 50 раз(а).
0Anim Buckyball.sm (107 КиБ) скачан 52 раз(а).
Buckyball.sm (176 КиБ) скачан 57 раз(а).
Laurent Fournier 02.08.2022 23:36:00
#20 Опубликовано: 24.05.2023 17:25:09
CLEISON ARMANDO MANRIQUE AGUIRRE
I guess we can not use the same matrix of contour point to get the area and de center of mass ... Or am I wrong ?
