1 страниц (6 вхождений)
another unit problem - changing the unit smath adds redundant fractions - Сообщения
#1 Опубликовано: 01.01.2018 15:40:40
as you can see in the example below here is another problem with units in smath.
As a civil engineer I need to have pressure-values to be printed in [kN/m²] and smath
prints results of calculations in [J/m³] by default. When I try to change the unit manually, a redundant expression
in the form of [m³/m³] appears and cannot be deleted. Not only that this does not look nice - this
"new unit" cannot be combined with other values having been define in [kN/m²] by me.
I suspect that there is a logic behind this I don't understand. So please help me if you have a clue.
Thank you, Nilsminimum example.sm (7 КиБ) скачан 77 раз(а).
#2 Опубликовано: 01.01.2018 16:36:55
nothing is wrong with unit handling in this example except your misinterpretation.
my guess is you copy-paste the meter cube and meter square from somewhere else.
you should recheck how you handle with power for your formulas.
regards
minimum_1.sm (7 КиБ) скачан 95 раз(а).
regards
#3 Опубликовано: 01.01.2018 18:32:28
Hello overlord,
you were totally right. I was handling the power wrong... just found out that I have to press the key twice to have it correctly.
Thank you for spending your precious evening time with helping a newbie out.
May the power be with you,
Nils
Nils
#4 Опубликовано: 01.01.2018 20:31:40
#5 Опубликовано: 26.01.2018 12:37:49
Dear,
in my file is experiencing a similar event, I would like, if possible, any tips on the error that I am commenting and a possible solution.
Thank you!
Error_unit.tif (93 КиБ) скачан 80 раз(а).
Dear,
Thank you!
Wrotenothing is wrong with unit handling in this example except your misinterpretation.
regards
#6 Опубликовано: 26.01.2018 13:07:45
FBRamires,
You need to set your units in I.2 to (kPa)^2 and units of I.3 to (kPa)^3.
Edit: See this example
example.sm (7 КиБ) скачан 88 раз(а).
Новые сообщения
Нет новых сообщений
