Export Matrix to txt without quotes
Export Matrix to txt without quotes - Сообщения
#1 Опубликовано: 17.03.2021 06:36:11
Denis Nikitin
Denis Nikitin
2 сообщений из 12 понравились пользователям.
Hellow.
I'm need help.
I'm want to export my Matrix with strings to new txt file.
My result - txt file with quotes near all values.
I need file without quotes.
Any Ideas?
LoadCombination2.sm (16 КиБ) скачан 75 раз(а).
#2 Опубликовано: 17.03.2021 09:43:40
You can try using the plugin "Clipboard Region"
Once installed, go to "insert > Clipboard region" and add one to the canvas, then add the variable in the input placeholder and click on the top arrow to send the data to the clipboard
sergio 17.03.2021 12:28:00
#3 Опубликовано: 17.03.2021 09:56:01
#4 Опубликовано: 17.03.2021 15:48:34
Wesly Centerwall
Wesly Centerwall
26 сообщений из 156 понравились пользователям.
Might just be easier to make a vbscript to drop your output file into that cleans up the data and removes the "". It would be an extra step, but easy to do.
#5 Опубликовано: 18.03.2021 09:05:36
Denis Nikitin
Denis Nikitin
Thank you for ideas.
This my temporary solution.
Now i'm want solve problem with paths... May be...
LoadCombination3.sm (15 КиБ) скачан 72 раз(а).
