Division with vector - Сообщения
I am trying to to the following:
n:=[1..1200]
s(n):=(1200-n)/1200
I(n):200/(1+2/s(n))
"I get an error divisor matrix must be square"
any suggestions???
Vijay
Vijay
WroteThank you for the response, I am new to this forum, is there a way I can send a .pdf file of the work I had done in MathCad, this will help you see what I am trying to do in Smath.
Vijay
Try this much easier:
1. compact as much as you can your part of Mathcad
2. PrintScreen, paste in Paint, clean
3. In your C:\ ... create a directory "Snippets"
4. Try to save your Paint as *.PNG in your "Snippets"
5. then => add file from the Smath forum
by double click on the *.PNG in the Snippets directory.
Alternatively, you can use implicit loops.
In any case make sure that you don't divide by zero.
To upload images or files, use the paperclip button ("Insert an existing...." )
matrix2.sm (19 КиБ) скачан 96 раз(а).
WroteWroteThank you for the response, I am new to this forum, is there a way I can send a .pdf file of the work I had done in MathCad, this will help you see what I am trying to do in Smath.
Vijay
WroteThank you for your efforts, that's what I am looking for.
I am re-sending the data with all the information.
I have a few questions on your previous post, there is an arrow above 2/s and I(u)^2.
What is that function. Also, you have used the value of u = 13.5?
Also, when you plot the graph, did you just type T(13.5) to get the graph?
1. The arrow is the vectorising operator [same as Mathcad].
2. 'u' is the wild parameter of same nature as r1,r2
3. The system runs over 'n' taken into account wrt the vectorised arguments.
4. Shift@ to get the plot region, type T(13.5) then [ to get the index operator
then type x. The Smath plot argument is 'x'. So, by indexing, it will plot over
the running 'x'. If you want to plot ln(x), just type ln(x) in the plot place holder.
I will try to code your latest information, but busy next three days.
WroteI will try to code your latest information
Now, you have another story [a different project].
Vijay(1).sm (26 КиБ) скачан 88 раз(а).
Wrotestarting from the basics, hope it might help you
example.sm (17 КиБ) скачан 203 раз(а).
Thank you so much, this really helps. May I suggest you post this as an example so everyone can benefit.
Vijay Khatri
WroteWroteI will try to code your latest information
Thank you, you have given me ideas that I can try to implement.
WroteMay I suggest you post this as an example so everyone can
You can mine Smath by visiting "Samples".
Without the circuit, it looks dead.
WroteWroteMay I suggest you post this as an example so everyone can
Attached is another similar file for which I have included the circuit diagram. I am assuming this will be posted in samples in this foroum.Файл не найден.Файл не найден.
Visit => Samples => Motor Analysis [20180316, 19:52]
Drawing was sharpened to the possible limit,
if you have a better one, please offer.
WroteSomething like this?
Vijay_CBG_Jean.sm (13 КиБ) скачан 79 раз(а).
Carlos
Thank you Carlos, just one question, how did you create the vertical line with multiple entries.
Новые сообщения
Нет новых сообщений
