include
include - include() function allow you to include simple definitions from other documents. - Сообщения
#21 Опубликовано: 29.11.2013 11:04:56
sublim21
sublim21
3 сообщений из 36 понравились пользователям.
Hey All,
Thanks for responding. I think i found the error.
The include function appears not to work, if the document it's running in is NOT SAVED.
once the document is saved, then the include extension works.
I'm going to keep playing with the include function (i've been waiting for smath to have this ability for a long long time).
Will report back with any errors.
Thanks!
-Pete
#22 Опубликовано: 30.11.2013 13:21:11
1402 сообщений из 1708 понравились пользователям.
Updated. Added support for strings. Error handling is changed.
Martin Kraska 30.11.2013 17:28:00
#23 Опубликовано: 01.12.2013 07:57:42
Preliminary handbook pages:
include demo.sm (4 КиБ) скачан 116 раз(а).
Вячеслав Мезенцев 01.12.2013 09:06:00, Radovan Omorjan 01.12.2013 09:15:00
#24 Опубликовано: 24.01.2014 14:10:29
sublim21
sublim21
There appears to be severe degradation on the time it takes to include a smath file, if that smath file contains a variable that is a string of length greater than 16.
Lets say I had two smath files as such
smathToInclude.sm
a:="some string of some length"
smathFile
include(smathToInclude.sm)
as the length of the string a increases so does the time it takes to include the file.
To test this, I created the following file.
smathFile
for b:=1 to 20 //do this 20 times to get a true sense of the include function time
c:=include(smathToInclude.sm)
And i changed the length of variable a to the following lengths, and got the following times
strlen TimeToInclude
10-.07
11-.07
12-.075
13-.085
14-.09
15-.095
16-.11
17-.169
20-.451
21-.74
22-1.16
23-1.851
24-2.841
25-4.519
30-49.0
It appears that string lengths above 16 chars is where the time to include shoots off the map - which makes me think the error has to be 16 bit representation.
Just letting you guys know,
-Pete
#25 Опубликовано: 24.01.2014 15:14:02
Thank you, Pete. I'll check this.
This behavior may be due to using a regular expression search. I am using a string representation of expressions to make some changes. Search using regular expressions can lead to such delays. It will take time for profiling the code.
#26 Опубликовано: 25.01.2014 08:48:58
Files to be used by include() do not typically reside in the document directory where they are used but at some central repository in a given installation. Candidates for such repositories might be the extensions/snippets or extensions/example directories in the settings directory as found by SettingsDirectory().
How about adapted versions of include() either with a second argument or (more convenient in the dynamic assistant) a special name like include("name.sm","examples" ) or example("name.sm" ) or include_example("name.sm" ) or whatever seems to be convenient?
Then we could use the extensions manager for distribution and download of such files. Would also be nice to have a mechanism to include the complete contents of extensions/snippets or whatever dedicated directory by default (source lib plugin).
#27 Опубликовано: 27.03.2014 05:22:48
wfoster982
wfoster982
I'm not sure if I am using "include" correctly.
But, when I include a file that has an expression with units, the defined object does not
manipulate the units correctly.
For instance -
LL.g=20*'lbf/{'ft^2}
LL.g*1/{25*'psf}=0.017*{'lbf*'m*'s^2}/{'ft^2*'kg}
When I multiply LLg times 1/25 psf; the result should be a unitless amount. It is coming up with
a mixed unit that cannot be manipulated or dealt with.
Can you help with this?
Great Program!!!
#28 Опубликовано: 27.03.2014 05:44:29
For instance -
Great Program!!!
Without using the include() function you get the same result?
EDIT: I have reproduced the problem. I can't advise something for now.
#29 Опубликовано: 27.03.2014 07:37:44
Updated. Try this [MATH]LL.g:eval(LL.g)[/MATH] before [MATH]LL.g*1/{25*psf}[/MATH].
#30 Опубликовано: 27.03.2014 10:54:50
Updated. Now file is searched for in two stages (if absolute path not used):
1. In the folder: /extensions/
2. In the document directory folder.
So, if you want to include some example sheet you need to use this: include( "examples\example1.sm" ) =
EDIT: Definitions in areas not supported.
Martin Kraska 27.03.2014 14:01:00
#31 Опубликовано: 25.04.2014 15:40:26
Updated. Added support for names which start with ` symbol (Linq).
#32 Опубликовано: 25.04.2014 17:43:28
Mike Kaganski
Mike Kaganski
Could you please address this limitation?
Thank you!
С уважением, Михаил Каганский
#33 Опубликовано: 25.04.2014 17:58:04
I'll do that little later.
Mike Kaganski 26.04.2014 04:14:00
#34 Опубликовано: 30.04.2014 12:21:05
Updated. Definitions in areas now supported and function works faster.
Davide Carpi 30.04.2014 17:35:00, Mike Kaganski 30.04.2014 18:30:00
#35 Опубликовано: 01.05.2014 05:40:09
"includes" do not work correctly if you use the comma for decimals and the "dot" to denote the subscript in the variables.
However I have seen in previous posts that Radovan had reported the problem to the name variables, and Martin has posted an example that uses a comma for decimals.
someone confirm?
#36 Опубликовано: 01.05.2014 10:29:45
someone confirm?
Updated. My fault. The algorithm was changed and I forgot about it.
sergio 01.05.2014 15:48:00
#37 Опубликовано: 23.06.2014 03:53:20
Updated (for compatibility with SMath Studio 0.97.5283).
UnitInfo.GetCurrentUnitName() changed to UnitsManager.GetCurrentUnitName().
#38 Опубликовано: 17.10.2014 04:04:31
brotjob
brotjob
7 сообщений из 71 понравились пользователям.
A lot of discussion has taken place here so I post my bug report here too. Or shall I use the bugtracker system instead?
Include does not work for variables defined in programming environment like if or for, see the example below, bread is not accessible in testmaster.sm
#39 Опубликовано: 17.10.2014 04:39:18
You can do this like on the picture below.
include() works with static global definitions (:=) only (static defs you can read directly from the sm-file, but for dynamic you must evaluate it first). I can't do that you want because this is too complicated. You may ask Andrey to add include() function in SMath Studio. He can do that.
#40 Опубликовано: 17.10.2014 10:18:25
brotjob
brotjob
This is a very elegant way for the above example. Thanks for showing me this. In cases where you have complex conditions and you want to define many variables in if statements it would not work. Also it does not work for loops for, while. That's why I will ask Andrey to implement this.
see feature request To implement an include() function able to handle dynamic definitions. Please vote!
