selecting an element from a matrix
selecting an element from a matrix - doesn't seem to work - Сообщения
#1 Опубликовано: 11.06.2015 17:25:36
pat
pat
Somehow selection of an element from a matrix doesn't seem to work.
Anybody knows what I am doing wrong? It keeps on giving an error, even when I open files made by others. (a red marker with system.string)
#2 Опубликовано: 11.06.2015 20:03:38
Can you append a file with a small example? (save the file after the error is shown, this should save also the error state)
#3 Опубликовано: 12.06.2015 11:50:23
pat
pat
Thank you for your response.
I have also attached a file.
example_errors.sm (4 КиБ) скачан 59 раз(а).
#4 Опубликовано: 12.06.2015 12:52:58
I opened your file without finding errors
#5 Опубликовано: 12.06.2015 15:02:37
pat
pat
thank you for your rapid response.
However my error message stays the same. See also attached screenshot. When I place the pointer over the red area, an error message appears, which says:
"method not found
system.string
smath.manager.unitinfo.getcurrentunitname (systm.string)"
#6 Опубликовано: 12.06.2015 17:08:27
pat
pat
Thank you for your response, the problem is fixed now!
