Fit Data Primer
Fit Data Primer - Fit Data Primer - Сообщения
#1 Опубликовано: 25.02.2019 22:02:56
This document, freshly brewed, is a recast of the Genfit Procedure.
Now the fitted coefficients result from β:=Minimize(init,iter)
1. compose the model
2. assign the vector gradient
3. β:=Minimize(init,iter) ... done
The 3 examples are 1/1 MCD 11 except that "iter" is not automated.
By setting "iter" high enough that will worth automated.
The setup is identical to MCD where Minerr is applied to SSE from
the solve block Given/Minerr [CG, QN, LM options]
Genfit algo [init, iter] UFO Copy.sm (106 КиБ) скачан 84 раз(а).
#2 Опубликовано: 26.02.2019 16:35:46
... refreshed for better publishing:
all respective modules collapsed in utilities.
This is a new example.
Genfit [HV_WEZ].sm (45 КиБ) скачан 56 раз(а).
#3 Опубликовано: 04.03.2019 19:36:58
... Frame work guide line, minimalist tool box.
Genfit Pharmacokinetics al_nleqsolve.sm (28 КиБ) скачан 62 раз(а).
Genfit [Algo Minimize(Cholesky)].sm (14 КиБ) скачан 58 раз(а).
GenfitMatrix Copy Master ToolBox.sm (59 КиБ) скачан 66 раз(а).
Genfit Pharmacokinetics L-M {ShortVersion] Copy.sm (101 КиБ) скачан 58 раз(а).
#4 Опубликовано: 04.03.2019 23:24:06
... original L-M c/w solution Table
Genfit Pharmacokinetics L-M Copy.sm (114 КиБ) скачан 78 раз(а).
